Convergence UDF
Old   July 26, 2009, 06:06
Default Convergence UDF
Jorge Muņoz
L3munoz is on a distinguished road
Hi!!!
I had another question...Convergence in my simulation case is obtained when Cm (moment coefficient) is uniformed. I wanted to do somehow a program to check the difference of Cm value in the last X iterations and see if it changed a lot or not in order to see convergence...
Shall I do it via UDF?? or is there any other way?? In case UDF is the answer, does anybody have idea of how to do it?? Do u know of any place where to have a look to know it better??
Thanks in advance!
Jorge.
L3munoz is offline   Reply With Quote
Old   January 4, 2011, 03:17
osman
gubarrani is on a distinguished road
hi Jorge !!!
do you have any progress with your problem? How did you solve it? I have also similar problem to check the convergence during iteration with the ca, cd or cm values.
guba...
gubarrani is offline   Reply With Quote
Old   January 4, 2011, 09:04
Jorge Muņoz
Hi gubarrani,
the only thing i can tell u is use monitors to check convergence. Not only residuals but also Cd values can be plotted and shown in Fluent. Moreover, you can get a .txt file where these values are written, helping you for checking it!
Regards,
L3munoz.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
