Update nodes with a ON_DEMAND UDF
Old   July 13, 2009, 16:36
Default Update nodes with a ON_DEMAND UDF
mrestrepo30 is on a distinguished road
I'm calculating the displacement of the nodes by comparing two grids at different times, so the way it does it, is that it goes through the faces of a thread, and then on each face goes through all the nodes. However, as some faces "share" nodes, I end up calculating the displacement for one node several times.
I tried to use something I found in the GRID_MOTION macro:
f_node_loop (f1, t1, n1) {
node1 = F_NODE(f1, t1, n1);
if (NODE_POS_NEED_UPDATE (node1))
NODE_POS_UPDATED (node1);
However when I use this the UDF never goes inside the IF, so I get no information from the nodes. Does anyone know how to implement this function on a ON_DEMAND macro?
I appreciate any comments about it!
mrestrepo30 is offline   Reply With Quote
nodes, on demand, update
Update nodes with a ON_DEMAND UDF mrestrepo30 FLUENT 0 July 13, 2009 15:36
Interpolation (Number of mapped nodes) Sam CFX 3 January 6, 2008 20:51
Number of nodes on block. Felix CFX 0 October 24, 2007 23:26
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
