Error compile file udf
Old   September 24, 2009, 02:59
czfluent is on a distinguished road
Originally Posted by dahu007 View Post
when I instaled Microsoft visual C++ I picked all the option. You have to install microsoft.net framework 3.5 ans above all the msdn library !
Good luck !
so I must install MS C++, framework 3.5, MSDN library ... uff
czfluent is offline   Reply With Quote
Old   September 24, 2009, 07:50
matth
dahu007 is on a distinguished road
Yes normaly it should work ! Good luck !
dahu007 is offline   Reply With Quote
Old   September 25, 2009, 11:28
Peter
pifou74 is on a distinguished road
Perhaps a stupid answer :
Have you tried to create a dll with your udf and to load it without using the compilator from fluent?
pifou74 is offline   Reply With Quote
Old   September 25, 2009, 13:16
matth
yes ! I start fluent with the VC++ command and then I created the dll using define- user define function- compiled-build. When the lybrairy is built you can start it using load !
Old   September 26, 2009, 14:24
no I īm not trying any others C++ compilator ...
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 15:30
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
UDF source file zhou FLUENT 3 September 29, 2003 12:53
