Anisotropic orthotropic species diffusivity
Old   June 3, 2009, 15:37
Question Anisotropic orthotropic species diffusivity
gemini is on a distinguished road
Does anybody have an idea how anisotropic or orthotropic species diffusion coeffients can be used in FLUENT via UDFs. I searched everywhere but did not find any information about this issue.
thanks.
gemini is offline   Reply With Quote
Old   June 3, 2009, 16:25
mj sharawi
mj_no7 is on a distinguished road
Hi again Gemini ,
You can try to implement your species as UDS's, then use DEFINE_ANISOTROPIC_DIFFUSIVITY to define you diffusion coefficients. (I know that this will be really hard if you have more than 6 or 7 species).
To account for reactions, you can add thier effect as sources in the energy and the species equations.
Regards,
MJ
mj_no7 is offline   Reply With Quote
Old   June 4, 2009, 08:59
Originally Posted by mj_no7 View Post
Hi again Gemini ,
Regards,
MJ
Hi MJ
I think the only way to implement anisotropic species diffusivity is the way you stated. FLUENT has drawbacks in this point and also definition of diffusion coefficients in full multicomponent diffusion.
I was considered the way you mentioned above before, but I am in the last six months of my work and I am not sure that I can handle the equations for 4 species in this limited time (numerical stability etc.). Also, in my work I always faced up limitations of FLUENT, so I am hesitating to implement my custom species transport balance.
Anyway, for example if I try to implement species transport as UDS, I think, I
- need to define new fluid material without having species transport enabled and momentum+energy balance activated.
- need to write density, viscosity, thermal conductivity, molecular weight, Cp, UDFs without accessing fluent database since without enabling species transport I assume that I have no access to Fluent database indise UDF
- need to write diffusion coefficient udfs
- need to learn how to implement energy source due to species transport. In this case definition of Cp is sufficient?
is there any point that I missed?
Thank you.
Best wishes,
Gemini
Old   June 4, 2009, 15:01
mj sharawi
I think this is all. I am not sure if you need also to account for enthalpy of formation as a source term in the energy equation.
good luck,
MJ
Old   June 4, 2009, 15:07
good luck,
MJ
Thank you MJ, I'm working on it, I will write here if I came up any interesting issues about modeling.
bye..
Old   October 25, 2010, 11:27
Munir Ahmed Khan
Munir.Khan is on a distinguished road
bye..
Have you solved the problem? I need help in the same.
Munir.Khan is offline   Reply With Quote
Orthotropic Diffusivity in Fluent Bharath FLUENT 1 November 7, 2011 16:42
Species Diffusivity in PEMFC Simulation circle2000 FLUENT 0 September 20, 2004 23:12
Scalar Transport and Species Diffusivity UDF's David Harvey FLUENT 0 December 5, 2003 02:45
question about Species diffusivity zhou1 FLUENT 3 November 5, 2003 03:39
Species diffusivity zhou1 FLUENT 0 November 4, 2003 18:23
