Writing UDF for DPM
Old   May 8, 2009, 19:18
Default Writing UDF for DPM
Cantstandit is on a distinguished road
I'm trying to write UDF that will inject particles with the initial velocities equal to those in cell of injection. Its my first UDF so I realy don't have any expirence, please help me!
This is what I wrote so far, it compiles but won't work.
#include "udf.h"
DEFINE_DPM_INJECTION_INIT(velocity_magnitude, I){
Particle *p;
cell_t cell;
Thread *cthread;
loop(p,I->p){
cell = P_CELL(p);
cthread = P_CELL_THREAD(p);
P_VEL(p)[0] = C_U(cell, cthread);
P_VEL(p)[1] = C_V(cell, cthread);
P_VEL(p)[2] = C_W(cell, cthread);
Actually it works if I hook it up to 1 injection, but when I try to do it with 2 injections at the same time it returns error
 The udf-inject-init property was changed for  2 injections
Error: SET-CDR!: invalid argument [1]: wrong type [not a pair]
Error Object: #f
Cantstandit is offline   Reply With Quote
Old   May 11, 2009, 02:48
Amir's Avatar
Amir
Amir is on a distinguished road
hi,
I propose you to use DEFINE_DPM_SCALAR_UPDATE macro and use
P_VEL0 in your code.
good luck,
Amir is offline   Reply With Quote
Old   May 11, 2009, 16:16
P_VEL0 is velocity of particle at the entry of current cell?
how do I make sure that "current cell" is the injection cell?
I want only to *inject* them at certain velocity (and DEFINE_DPM_SCALAR_UPDATE does not have Injection *I as an argument)
Old   May 12, 2009, 08:43
Amir's Avatar
Amir
hi,
to define injection you can use Injection *I
P_VEL0(p) is a special macro and it does not modified when
you use DEFINE_DPM_SCALAR_UPDATE
so it returns the value due to the first cell that contains the particle.
Old   May 12, 2009, 08:48
Amir's Avatar
Amir
note that the DEFINE_DPM_SCALAR_UPDATE has the particle argument
so you can use it without definition of injection.
also you do not to need to use a loop on particle or injections using this
define macro.
Old   September 20, 2010, 21:30
Default run this macro parallel
Shawn Fotovati
sfotovati is on a distinguished road
Dear friends, I wrote a UDF using DEFINE_DPM_INJECTION_INIT and this work perfectly while I am using single CPU. As long as I am chaning it to parallel, then the particles go out of the geometry and everything is wrong. should I take any consideretaion while I want to run it in Parallel?
sfotovati is offline   Reply With Quote
writing UDF for modelig mass transfer for VOF ardalan soleymani FLUENT 0 July 11, 2007 02:09
Seek help in writing UDF Jack Martinez FLUENT 9 June 14, 2007 11:24
New to writing UDF Sandilya FLUENT 0 May 31, 2007 13:03
Writing UDF for Robbins Bounday Condition KKLAU FLUENT 1 April 7, 2004 00:58
Macros for writing UDF for porosity umesh FLUENT 1 June 13, 2003 05:20
