Parallelizing a udf
Old   April 27, 2009, 14:09
Default Parallelizing a udf
Jack nedermans
coolengineer is on a distinguished road
I have a working udf. How can I use this udf for parallel computing. I have a look at the udf manual in Fluent. But it is quite complicated. What do you suggest me to do?
Waiting from you.
Thank you.
coolengineer is offline   Reply With Quote
Old   May 4, 2009, 13:57
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If you post your udf, maybe somebody can help you.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 4, 2009, 14:23
Default Cg-motion
Jack nedermans
It is a simple CG-MOTION UDF.
Old   May 6, 2009, 04:40
Max
coglione is on a distinguished road
Hello coolengineer,
I think a really simple CG_MOTION (i.e. linear velocity or omega are given and not computed in some sophisticated way with data from cells that may reside in different partitions) will not require any parallelization of the code by you. Just compile it in parallel mode and run the case.
cheers
coglione is offline   Reply With Quote
Old   February 27, 2013, 06:15
Kanarya is on a distinguished road
hi
I have code which is working on serial but doesnt work in parallel. I am using execute_end function to save outlet mass flow and then by using define_profile function and saved data,I am giving my inlet BC.
do you have any idea about problem?
thanks in advance!!!
Originally Posted by coglione View Post
Hello coolengineer,
cheers
Kanarya is offline   Reply With Quote
parallel computing, parallelize, udf
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
Help Parallelizing UDF - THREAD_STORE Mario Santillo FLUENT 4 June 21, 2006 15:21
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
