problem of dynamic mesh for a piston model
Old   April 1, 2009, 12:16
Default problem of dynamic mesh for a piston model
pipin
pipin is on a distinguished road
I have to model a problem of a piston in a cylinder and i want to make an UDF in order to move the piston 2 mm before then 6 mm behind.
have you any idea about the UDF to do this? and any advices for this kind of problem?
Thanks
pipin is offline   Reply With Quote
Old   April 2, 2009, 01:34
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you may use the macro DEFINE_CG_MOTION.
Please refer to chapter 2.6.1 from help
Example:
* 1-degree of freedom equation of motion (x-direction)
* compiled UDF
/#include "udf.h"
static real v_prev = 0.0;
DEFINE_CG_MOTION(piston,dt,vel,omega,time,dtime)
Thread *t;
face_t f;
real NV_VEC(A);
real force, dv;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
force = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force += F_P(f,t) * NV_MAG(A);
end_f_loop(f,t)
/* compute change in velocity, i.e., dv = F * dt /mass velocity update using explicit Euler formula */
dv = dtime * force / 50.0;
v_prev += dv;
Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force);
/* set x-component of velocity */
vel[0] = v_prev;
-mAx- is offline   Reply With Quote
Old   August 2, 2010, 15:35
Zdeth
zdeth is on a distinguished road
Can anyone explain to me the use of resetting the velocity? "NV_S (vel, =, 0.0);"
I am also trying to model a simple piston in a tube but am having problems with the motion/results
zdeth is offline   Reply With Quote
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 22:17
Dynamic Mesh Problem - please help! Hila FLUENT 0 August 19, 2006 05:19
Dynamic mesh problem Karthick FLUENT 1 October 11, 2004 06:47
Boundary conditions for dynamic mesh model lingo FLUENT 4 May 7, 2004 05:02
