Re: ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM
Old   December 14, 2008, 16:49
Default Re: ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM
Kirlangic
Problems:
1. 'nmake' is not recognized as an internal or external command, operable program or batch file
2. c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2143: syntax error : missing '{' before ':'
3. c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':'
4. c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
5. c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';'
6. c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
7. LINK : fatal error LNK1104: cannot open file "kernel32.lib"
8. valve.obj : error LNK2019: unresolved external symbol __imp_Compute_Force_And_Moment referenced in function f_valve
9. valve.obj : error LNK2019: unresolved external symbol __imp_Lookup_Thread referenced in function f_valve
etc, etc..
I had the similar compiling problems on 64 bit Windows Vista with Microsoft Visual Studio 9.0.
The final solution that worked for me is easy. You don't touch any system and environment variables or change any default settings or installation folders (at least by hand)
Step 1: Launch "Visual Studio 2008 x64 Cross Tools Command Prompt" which is under All Programs > Microsoft Visual Studio 2008 > Visual Studio Tools (http://msdn.microsoft.com/en-us/library/76712d27.aspx)
Step 2: Run vcvarsall.bat from this command prompt. This file is most probaly at "C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" (http://msdn.microsoft.com/en-us/library/x4d2c09s.aspx)
Step 3. Run fluent from this command prompt. It will work fine..
Regards,
Ozgur
Old   April 20, 2011, 05:26
alven
alven299 is on a distinguished road
Hi Kirlangic,
I'm experiencing the same problems: 2-6. I'm using xp 64 bit and MS visual studio 9.0. I have followed your steps but still couldn't resolve the issue. I'm wondering perhaps it is my UDF that has problem. Could you please try to compile the following UDF in your computer and see whether it works? Also, do I need a header file for the compilation process? If yes, do I copy it from the fluent6.3.26\src\ folder?
here is my UDF:
#include "udf.h"
DEFINE_PROFILE(inlet_temperature,t,i)
{real time;face_t f;
begin_f_loop(f,t)
{time=CURRENT_TIME;if(time<2)
F_PROFILE(f,t,i)=300;else
F_PROFILE(f,t,i)=340;
}end_f_loop(f,t)}
Many thanks.
alven299 is offline   Reply With Quote
Old   April 2, 2012, 23:03
Ngô Ích Sơn
manowars is on a distinguished road
Hi all
Same here, I followed your steps. However, the error still occurred.
I am using OS windows xp 64 bit and MS visual C 2010.
Here is my steps:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>vcvarsall.bat
Setting environment for using Microsoft Visual Studio 2010 x86 tools.
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>C:\Fluent.Inc\ntbin\win64
\fluent.exe -r6.3.26
Many thanks
Regards,
manowars is offline   Reply With Quote
Old   April 5, 2012, 11:23
alven
I upgraded my FLUENT to v12 and problem solved. No more UDF compiling issue.
Old   April 10, 2012, 07:59
wu
worldexpress is on a distinguished road
How to set environment variables for compile in fluent 12.thank you.My fluent is v12,and vs is v2010.
worldexpress is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Radial fan problem : Attn Razvan and all Farhath FLUENT 0 September 26, 2007 05:18
Kind attn:problem in DEFINE_SOURCE in my UDF Phanindra FLUENT 1 February 23, 2007 10:03
about compile problem stanta Siemens 0 July 10, 2005 00:19
udf compile problem inhalation FLUENT 0 May 13, 2004 04:41
