load libudf problem
Like Tree1Likes
Old   March 21, 2007, 12:28
Default Re: load libudf problem
  #21
Shaik Rizwan
welll guys i got the solution for all the not able to find nmake etc etc stuff, il post a detailed reply soon under a separate heading.
Regards Razwan
Old   October 13, 2010, 05:15
asal
asaleghahreman is on a distinguished road
hi everyone.I have the same problem.when I push build botton,I recived this error:
The system cannot find the file specified.
(system "copy C:\FLUENT~1.26\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2d")()
i saw log file,It was:
NMAKE : U1073: don't know how to make '..\..\src\a.c'
Stop.
what should I do to solve this problem??
thanx
asaleghahreman is offline   Reply With Quote
Old   November 29, 2010, 07:00
Iodel is on a distinguished road
Hi everybody. I had the exact same problem and here's how I solved it:
Situation:
- I am currently using the Fluent package contained in Ansys v12.0
- I am working on a Windows 7 (32 bit) OS
- I have installed "Microsoft Visual C++ 2008 - Express Edition" (I've also tried with the Visual C++ 2010 but it seems not to be compatible with Ansys v12.0)
Solution:
- I've modified my environment variables in this way:
1) Start -> Computer -> Properties -> Advanced Options -> Environment variables -> PATH -> Edit
2) I've then added the following adresses to the existing list:
- C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools;
- C:\Program Files\Microsoft Visual Studio 9.0\VC\bin;
- C:\Program Files\ANSYS Inc\v120\fluent\ntbin\ntx86;
- Then I've created a folder "TEST" where I put my case files AND the .c file containing my udf "udf_test.c"
- I've opened my case's workbench and double-clicked on "setup", opening FLUENT
- Define -> User-Defined -> Functions -> Compiled
- Now on Source Files I've added my source file "udf_test.c"
- On "library name" I've kept the default library name "libudf" and clicked on the "Build" button
- Now, on the working directory "TEST", FLUENT created a new folder containing the library and called "libudf"
- I've then copied the "libudf" directory and pasted it into: mycase_files -> dp0 -> FFF -> Fluent
- At last I clicked on the LOAD button in Fluent, and my udf library was successfully loaded in Fluent
Hope it will work for you as well.
Iodel is offline   Reply With Quote
Old   August 23, 2013, 03:22
Default hi
  #24
tran trung
tranvantrung551987 is on a distinguished road
Originally Posted by Tania
;140033
I had the same problem when I run Fluent in windows. But then I installed VisualC++, everything worked. It seems that you need to have a compiler installed in the computer. This is how I solved my problem.
Here are the steps, I do to run an Udf file.
1- put the udf file in my case directory.
2- Go to Define>user-defined Functions>Compiled> There you should first add the udf file.
3- Click on BUILD
4- Click on LOAD
..it should work.
Tania
can you show step by step what you do by attached flie
thanks you so much
tranvantrung551987 is offline   Reply With Quote
Old   November 1, 2013, 00:53
Ngô Ích Sơn
manowars is on a distinguished road
In my case,
1. first install SDK 2.0
2. Open SDK 2.0 command prompt, type: Fluent
3. Then go to Define>User Defined> Function> Compiler
Remember to put the udf file in the same folder with case files
manowars is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
high CPU load with no computation going on & Pressure coefficient output problem spetsnaz26 FLUENT 0 September 30, 2011 06:25
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
