Running fluent with udf in batch mode
Old   November 1, 2006, 21:27
Default Running fluent with udf in batch mode
zonexo
May I know if it is possible to use udf files in batch mode?
I've successfully loaded the udf and run the simulation using GUI. However, it is very slow. I tried to batch mode but there are some errors. It worked when there is no udf loading
1stly, it says file not found in the error log file. Then I tried to copy the library libudf.so to the directory and it says
Error: open_udf_library: ELF file data encoding not little-endian
I guessed it could be that the library file is compiled in another system hence it can't work.
Does anyone have a solution for this? Thanks
Old   November 8, 2006, 01:42
Default Re: Running fluent with udf in batch mode
Ray
Dear sir,
If you have already solved the problem, please share with us.
Thanks.
Ray
Old   March 10, 2012, 08:50
Bionico's Avatar
Flavio
Bionico is on a distinguished road
I have the same problem: could anyone tell me how to solve it?
Bionico is offline   Reply With Quote
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 11:26
Parallel Fluent Error in Batch Mode Justin FLUENT 3 November 28, 2016 11:50
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 19:02
Running FINE on Batch Mode Chze Yeong Tang Fidelity CFD 2 March 26, 2003 16:41
