February 19, 2018, 06:24 |
#21 | |
Rep Power: 27 |
if(F_UDMI(f,t,0)<315; |
February 19, 2018, 06:29 |
#22 |
Ahmed Awwad
Rep Power: 8 |
I compile and it works until time 8400 sec and after than the inlet temperature didn't changed anymore, the outlet temperature was 297.15 K and inlet temperature was 302.15 K
February 19, 2018, 06:30 |
#23 |
Rep Power: 27 |
Impossible.
I believe that you clicked the 'build' button, and that you think that you compiled. But with the code above, there must have been an error showing in the text user interface. |
February 19, 2018, 06:34 |
#24 | |
Rep Power: 27 |
February 19, 2018, 06:37 |
#25 |
Ahmed Awwad
Rep Power: 8 |
Yes, You are right I just click build and no error appear, what do you think about the error and how I can solve it?
February 19, 2018, 06:40 |
#26 |
Ahmed Awwad
Rep Power: 8 |
No error appears
February 19, 2018, 06:43 |
#27 |
Rep Power: 27 |
An error appears, I guarantee you. You are just not looking in the right place.
Look in the text zone that is normally on the bottom right of your Fluent screen. After you click 'build', text is printed there. Look at this text, this contains the errors. |
February 19, 2018, 06:58 |
#28 |
Ahmed Awwad
Rep Power: 8 |
these are screen shoots after build and compile respectively
February 19, 2018, 07:09 |
#29 |
Ahmed Awwad
Rep Power: 8 |
I got this message after 8000 sec
February 19, 2018, 07:16 |
#30 |
Rep Power: 27 |
"build" and "compile" is the same thing.
If there is no error on your screen (which I can not see from your screen shots), then you are not compiling the code that you shared on this thread. |
February 19, 2018, 07:17 |
#31 |
Rep Power: 27 |
February 19, 2018, 07:20 |
#32 |
Ahmed Awwad
Rep Power: 8 |
February 19, 2018, 07:24 |
#33 |
Rep Power: 27 |
"this error" is you. You use a different code in Fluent than you post on this forum.
If you want help with the code that you use in Fluent, post the code that you use in Fluent. |
February 19, 2018, 07:40 |
#34 |
Ahmed Awwad
Rep Power: 8 |
Here is the .C file I used, it is the same, and why I use different code and ask about another one, I did not want to bother you
February 19, 2018, 08:34 |
#35 |
Rep Power: 27 |
Please look more carefully. The code that you attached is NOT the same as the code that you posted here earlier.
February 19, 2018, 16:09 |
#36 | |
Ahmed Awwad
Rep Power: 8 |
Regards the attached one are there any problems because the temperature didnot changes after 8000 sec. |
February 20, 2018, 03:34 |
#37 |
Rep Power: 27 |
I am sorry but it takes too much time and energy to help you in this way. I'm out.
February 20, 2018, 05:17 |
#38 |
Ahmed Awwad
Rep Power: 8 |
[QUOTE=pakk;682170]I am sorry but it takes too much time and energy to help you in this way. I'm out.[/QUOT
Thanks for your much time and energy and I appreciate your help |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 07:56 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 01:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 08:14 |
UDF problem | chiseung | FLUENT | 4 | January 10, 2002 10:58 |
