Interpreted UDF in parallel
Old   May 17, 2005, 12:05
Default Interpreted UDF in parallel
David Chabot
Hi, I am wondering if it is possbile to use an interpreted UDF (simple function describing a time-dependent velocity inlet) instead of compiled UDF while running a case on a parallel computing cluster? I'm having problems compiling that UDF but I thinking that this struggle might be avoidable? Any comment is welcome.
Old   May 18, 2005, 04:02
Default Re: Interpreted UDF in parallel
Luca
Hi, do you have problems when you interprete your UDF in the serial solver? Luca
Old   May 19, 2005, 11:06
David
Hi Luca, Thanks for responding. To answer your question, no I do not have problem interpreting my UDF in the serial solver. My problem at the moment is that I cannot compile it in the serial solver although I have set the environment variables as described on the Fluent online help site. I might be able to avoid this problem... Do you know if it is possible to use such a interpreted UDF on a parallel solver? Thanks again David
Old   May 19, 2005, 11:10
Luca
I not sure you can use interpreted UDF in the parallel solver. Have you set the environmet variables for visual C++?Luca
Old   May 19, 2005, 12:45
David Chabot
Hi Luca, I tried to set up the Visual C++ environment variable s as described in the following link:
http://www.fluentusers.com/support/i.../udfguides.htm
After having set the variables, I typed cl in a command prompt window. Ok. I get a similar message but the version of the compiler is slightly different (Compiler Version 12.00.8186 instead of 12.00.8804.)
When I type link/version in a new prompt window I unfortunately do not get what I should. I get the following:
Microsoft (R) Incremental Linker Version 6.00.8168 Copyright (C) Microsoft Corp 1992-1998. All rights reserved. LINK : fatal error LNK146: no argument specified with option "/version"
Note that the linker version is not the one suggested by Fluent. I downloaded Microsoft Visual Studio 6 full version of Service Pack 6 and installed it so I'm surprised to see that the versions (both for compiler and linker) differ from what is suggested on the Fluent website.
Any suggestions? Let me know if you'd like to see the log file generated by FLuent when attempting to build the library. Many thanks David
Old   May 19, 2005, 12:48
Luca
Yes send me the log file. Luca
Old   May 19, 2005, 12:51
David Chabot
Will do. I will send it by email.
Old   May 20, 2005, 10:16
David Chabot
Hi all, just to follow up with this problem. I turned out that the problem was within my UDF code. When interpreted, I had no problem. When compiled, the compiler picked up syntax errors that were causing this problem. Regards, David
Old   May 30, 2012, 04:18
amindavari is on a distinguished road
could anyone help me: i provided an udf that set a profile on the boundary, at first i couldnt even interprete this udf, however by adding two lines in code i finally could interprete it. now i encounter a new problem, when i start iterating, an error entitled "Floating point error: invalid number" appears. what should i do?
thank you in advance
#include "udf.h"
DEFINE_PROFILE(heatflux, thread, position){
#if !RP_HOST
real y[ND_ND]; /* this will hold the position vector */
real z;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(y,f,thread);
z = y[2];
F_PROFILE(f, thread, position) = 283889.07*cos((4.0*atan(1.0)/0.815)*(z+0.01005));
end_f_loop(f, thread)
#endif
amindavari is offline   Reply With Quote
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 10:48
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 14:53
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 12:19
UDF in parallel version. yobee FLUENT 0 August 17, 2004 05:12
