UDF: CONTROL DRAG/EXCHANGE COEFF
Old   June 4, 2004, 01:47
Default UDF: CONTROL DRAG/EXCHANGE COEFF
Luis
Hi everyone,
I am solving a 2-phase flow, and need to control the drag using an UDF.
I am trying to apply the DEFINE_EXCHANGE_PROPERTY macro to define the drag coefficient. When I use my UDFs for a simple case, without important direction changes, the results are reasonable. However, for a more complex geometry, even if the UDF is written with the same equations that are presented in the Fluent documentation, I get weird flow patterns, which I don't see if I use a pre-defined Fluent drag model.
Has anyone been successful controlling the drag / exchange coefficient using an UDF?
Any help will be extremely appreciated,
Luis
Old   June 6, 2004, 15:37
Default Re: UDF: CONTROL DRAG/EXCHANGE COEFF
ap
This sounds strange. I'd check the code, because the DEFINE_EXCHANGE_PROPERTY just replaces the predefined FLUENT drag function.
Try to follow the example reported in UDF manual.
To control the value, just define a UDM and store the value returned by the UDF there. You can then plot using contours for example.
Hi
ap
Old   June 8, 2004, 13:05
Luis
Hi ap,
Thanks for your answer.
Before writing the UDF I read carefully the examples, and I esentially tried to follow one of them.
My UDF returns the exchange coefficient, instead of the drag function, but I think that's what you meant.
Checking the UDF returned values sounds like a good idea, I'll try that.
Regards, Luis
Old   June 8, 2004, 14:29
ap
Yes, I meant the drag coefficient. Sorry for the misunderstanding.
Hi
ap
Old   July 16, 2012, 07:27
Default Udm
Majid Mostafazadeh
forgottenman is on a distinguished road
Hi
How did you make a UDM for DEFINE_EXCHANGE_PROPERTY?
UDM needs to be made in a loop, how did you write that loop?
Thank you
forgottenman is offline   Reply With Quote
UDF control time cfdhydraulic FLUENT 0 September 23, 2010 05:34
access drag coeff and udf for granular temp jwwang FLUENT 0 May 22, 2006 01:48
UDF to control autowrite option scubme FLUENT 0 January 22, 2005 12:47
UDF to control Static Pressure (in cylinder) James FLUENT 0 July 20, 2004 08:54
UDF for heat transfer coeff.. ravi FLUENT 2 July 9, 2004 01:09
