UDF code for condensation
Old   May 7, 2004, 04:32
Default UDF code for condensation
Dae Whan Kim
Hello! Does anybody has a udf code for condensation? I need udf code for source term of Volume Fraction Equation. This equation is at here. " http://gong.snu.ac.kr/down/on-line-d...ug/node681.htm " I will thanks to any kind of help.
Old   May 7, 2004, 23:07
Default Re: UDF code for condensation
Nr
Hi sorry for distrubing! I think I have the same problem to do with you! My project is to simulate the process of condensation on a cold free surface! For I am a newer Fluent user, so can you give me some suggestion or help for me to do this project! Thanks for your help!
Old   May 8, 2004, 22:04
co2
well, modeling condensation involves dealing with two phases - condensed liquid and yet to condense vapor.
you will have to write with a UDF to deal with conversion of vapor into liquid -- function of vapor pressure and temperature etc. I think the conversion back from the liquid to vapor will be some source term at the point -- at the same time you need to make sure that you take out same kg/sec out of the condensate -- I dont know of any already written code -- but I am also trying to play around with this problem -- I will let you know if I suceed.
Old   May 8, 2012, 23:17
Smile
Song Wenyu
foolstop is on a distinguished road
Originally Posted by co2
;112406
hi,guy
do you suceed in the process of condensation by Fluent?
foolstop is offline   Reply With Quote
Brownian Motion UDF Code Confuser FLUENT 3 August 13, 2021 02:14
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 11:55
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
