UDF to update Operating pressure
Old   December 9, 2003, 02:56
Default UDF to update Operating pressure
Rahul
Hi All, I am performing a analysis which require to update operating pressure based on other parameters. Can someone suggest me how to tackle this problem? As operating pressure doesn't have hook it may need some other way like adjust function to take care of this. Thanks in advance, Rahul
Old   June 19, 2013, 16:53
Mahboobe Mahdavi
Mahboobe365 is on a distinguished road
could you find the solution for this problem?
Mahboobe365 is offline   Reply With Quote
Old   June 26, 2020, 03:01
Arun raj.S
arunraj is on a distinguished road
Is there a solution to the problem?
arunraj is offline   Reply With Quote
Old   June 26, 2020, 04:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you can use TUI command to set operating pressure.
If you need to make it under criteria you can use scheme + TUI.
It is possible to transfer data from UDF to scheme using rpvariables
Look for rpvar in Ansys FLuent Customization manual
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   June 26, 2020, 04:17
Arun raj.S
Dear Alexander,
Thank you for the reply.
I want to apply corrected operating pressure as UDF.
Is this what you mean? Can I add this at the end of DEFINE_ADJUST after calculating new operating pressure.
Abs_Pres = 0;
DEFINE_ADJUST(PRESSURE, domain)
p_op_new =mass_vap_old*(TIME_STEP*AAA*DDD);
RP_Set_Real("operating-pressure", p_op_new);
thread_loop_c(t,d)
begin_c_loop(c,t)
Abs_Pres = ABS_P(C_P(c,t), p_op_new);
end_c_loop(c,t)
return Abs_Pres;
(or)
thread_loop_c(t,d)
begin_c_loop(c,t)
return p_op_new;
end_c_loop(c,t)
Old   June 26, 2020, 05:39
Alexander
it could be something like this, however, I'm not sure if it works or not, you should test first. Make few timesteps and check operating pressure
In your code Abs_Pres is calculated each time during cell/thread loop.
So you will get Abs_Pres only from last cell.
What exactly you want? If you want to get the field of recalulated pressure you may use UDMIs
Abs_Pres = 0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = Abs_Pres;
end_c_loop(c,t)
best regards
Old   June 26, 2020, 05:54
Arun raj.S
Thank you so much for your reply.
I solved with the following command. I hope it is correct. Can you please confirm?
(rp-var-define 'p_op_new 0.0 'real #f)
/define/operating-conditions/operating-pressure (rpgetvar 'p_op_new)
the role of operating pressure in flow simulation sunflower FLUENT 1 December 20, 2010 22:24
Floting operating pressure Edwardo FLUENT 0 November 12, 2005 17:08
correct UDF code for unsteady pressure boundary James W FLUENT 0 November 2, 2005 12:38
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
