first time with UDMI
Old   October 1, 2003, 11:31
Default first time with UDMI
Andrew Garrard
I am trying to use UDM for the first time. I have written the part of the code shown below, where eta(f) is a function in another part of the code. I would have assumed the same value that is printed for over_pot in the printf line would be the value that appeared in my xy plots in fluent. When I make the xy plot I only get a value of 0.00000. Any reason why this is occuring?
DEFINE_PROFILE(tile_conc_spec, thread_sol, i)
face_t f;
begin_f_loop(f, thread_sol)
real over_pot = eta(f);
F_UDMI(f, thread_sol, 0) = over_pot;
printf ("\nover_pot = %g, at face %d", over_pot, f);
F_PROFILE(f, thread_sol, i) = c_bulk*concvar(f)/(concvar(f)+1);
} end_f_loop(f, thread_sol)
Old   October 1, 2003, 16:40
Default Re: first time with UDMI
ap
You're saving your values only on the boundary where you define your profile, so you should be able to plot it only there, by selecting the boundary in the XY-plot panel.
Hi
ap
Old   October 2, 2003, 05:41
Andrew Garrard
The thread that I am defining the profile on "thread_sol" is the same one that I am applying the UDM to, it is also the one I am trying to XY plot in fluent. I still get 0.000 for all face values on that face thread. Is it because all the values are negative?
Old   October 2, 2003, 08:49
ap
I don't think this has to do with the sign of values.
Hi
ap
Old   February 29, 2012, 00:01
Balakrishnan
balki is on a distinguished road
Hi Andrew, I hope you would have solved this problem. I'm also facing the same problem can you please let me know the solution?
Thanks
krishnan
balki is offline   Reply With Quote
Old   November 22, 2012, 11:17
Kanarya is on a distinguished road
Thanks
krishnan
Hi I have the same problem. the values are 0.did u solve the problem my code is:
#include "udf.h"
DEFINE_PROFILE(outlet_mf,t,i)
face_t f;
real flow;
begin_f_loop(f,t)
flow+=F_FLUX(f,t);
F_UDMI(f,t,0)=flow;
end_f_loop(f,th);
thanks in advance!!!
Kanarya is offline   Reply With Quote
Old   November 24, 2012, 00:30
Balakrishnan
Hi Kanarya, I had the same problem. When I used C_UDMI instead of F_UDMI, it worked as expected. I dont know why.
Old   November 24, 2012, 09:43
Thanks for the answer!
did you use the function F_FLUX(f,t)? how is it possible to read face and to save in cell?
thanks again...
Old   November 25, 2012, 05:24
Balakrishnan
Originally Posted by Kanarya View Post
thanks again...
Hi, I didn't use F_FLUX.
how is it possible to read face and to save in cell? I have the same doubt, anyhow as I said earlier, C_UDMI solved the problem. If you find the answer, please let me know....
Balki
Old   November 25, 2012, 19:49
which function is suitable to save mass flow at outlet..do you think, is define_execute_at_end OK for it?
thanks for advance..!
Old   November 30, 2012, 11:54
Balki
Hi Balki,
#include "udf.h"
DEFINE_EXECUTE_AT_END(measure_mass_flow)
real mass_flow;
real mass_flow_g;
Domain *d=Get_Domain(1);
cell_t c;
face_t f;
Thread *mixture_thread = Lookup_Thread(d,4);
Thread **pt = THREAD_SUB_THREADS(mixture_thread);
Thread *tp = pt[0];
Thread *ts = pt[1];
mass_flow=0.;
//mass_flow=0.;
mp_thread_loop_f(mixture_thread,d,pt)
if( THREAD_ID(mixture_thread) == 4 )
begin_f_loop(f,mixture_thread)
mass_flow+=F_FLUX(f,ts);
if(N_UDM > 0 && BOUNDARY_FACE_THREAD_P(ts))
C_UDMI(f,ts,0)=mass_flow;
end_f_loop(f,mixture_thread)
Message("mass_flow:%g/n",mass_flow);
I am trying to save mass flow at outlet. but it gives always zero, could you give me a hint? thanks a lot in advance!!!
Old   July 24, 2015, 11:12
Farzin
FarzinD is on a distinguished road
I also came up with this problem. I think its just not enough to have only Face User-Defined memory of a cell to make plots. Considering that Fluent calculates and stores variables on cell Centers, it is needed to store the value of both Cell and it's Face within a single User-Defined Memory Location.
FarzinD is offline   Reply With Quote
Old   October 4, 2017, 05:21
Default Dear freiends
  #13
sewgolam is on a distinguished road
Can you please explain how to make a C_UDMI in fluent.
i tryed to read the manual but still no clue what im doing. I want to store reaction product and give it back as mass source.
please help
sewgolam is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
