Yesterday, 04:44 |
Udf cluster run problem
Mushfiq Al Arafa
Dear Concern,
The journal file, the lines which compiles, loads and hooks the udf are marked in red. /rc /home/mus62929/Bubbler/bub10_4/Bubbler_Validation.cas.h5 /file/auto-save/root-name "/home/mus62929/Bubbler/bub10_4/regular_autosave" /define/user-defined/compiled-functions compile "libudf03" yes "Only_Modification_Power.c" "" "" /define/user-defined/compiled-functions load "libudf03" /define/phases/set-domain-properties/interaction-domain/forces/drag yes tomiyama yes user-defined "modification_factor::libudf03" /file/auto-save/save-data-file-every "time-step" /file/auto-save/data-frequency 10 /solve/initialize hyb-initialization /solve/patch/air ()(air) mp 1 /solve/set/time-step 1e-2 /display/set/contours/filled-contours yes /display/set/picture/driver png /display/set/picture/landscape yes /display/set/picture/x-resolution 1280 /display/set/picture/y-resolution 720 /display/set/picture/color-mode color /display/set/windows/text/date yes /display/set/windows/text/visible yes /display/set/windows/text/border no /display/set/windows/main/border no /display/set/colors/graphics-color-theme black /display/set/line-weight 2 display/set/contours/surfaces (plane-5) /display/set/contours/n-contour 25 /display/set/contours/auto-range no /display/set/contours/clip-to-range no /display/views/restore-view front /display/views/auto-scale /display/contour water vof 0 1 /display/save-picture watervof_%t /solve/execute-commands/add-edit command-1 no 10 "time-step" "/display/views/restore-view front" /solve/execute-commands/enable command-1 /solve/execute-commands/add-edit command-2 no 10 "time-step" "/display/views/auto-scale" /solve/execute-commands/enable command-2 /solve/execute-commands/add-edit command-3 no 10 "time-step" "/display/contour water vof 0 1" /solve/execute-commands/enable command-3 /solve/execute-commands/add-edit command-4 no 10 "time-step" "/display/save-picture watervof_%t" /solve/execute-commands/enable command-4 /solve/dual-time-iterate 1 20 /solve/set/data-sampling yes 1 no no /display/set/contours/filled-contours yes /display/set/picture/driver png /display/set/picture/landscape yes /display/set/picture/x-resolution 1280 /display/set/picture/y-resolution 720 /display/set/picture/color-mode color /display/set/windows/text/date yes /display/set/windows/text/visible yes /display/set/windows/text/border no /display/set/windows/main/border no /display/set/colors/graphics-color-theme black /display/set/line-weight 2 display/set/contours/surfaces (plane-5) /display/set/contours/n-contour 25 /display/set/contours/auto-range no /display/set/contours/clip-to-range no /display/views/restore-view front /display/views/auto-scale /display/contour water vof 0 1 /display/save-picture watervof_%t /solve/execute-commands/add-edit command-1 no 10 "time-step" "/display/views/restore-view front" /solve/execute-commands/enable command-1 /solve/execute-commands/add-edit command-2 no 10 "time-step" "/display/views/auto-scale" /solve/execute-commands/enable command-2 /solve/execute-commands/add-edit command-3 no 10 "time-step" "/display/contour water vof 0 1" /solve/execute-commands/enable command-3 /solve/execute-commands/add-edit command-4 no 10 "time-step" "/display/save-picture watervof_%t" /solve/execute-commands/enable command-4 /solve/dual-time-iterate 1 20 /file write-case-data /home/mus62929/Bubbler/bub10_4/Bubbler_result.cas.h5 /exit ok The compilation and loading is working, but the hooking of the udf is not working. The lines are market in red, where the problem can occur. Copy "/home/mus62929/Bubbler/bub10_4/Only_Modification_Power.c" to "/home/mus62929/libudf03/src" Working... # linking to ../../src/Only_Modification_Power.c in lnamd64/3ddp_host # building library in lnamd64/3ddp_host # Generating udf_names.c because of makefile Only_Modification_Power.c # Compiling udf_names.o because of udf_names.c # Compiling Only_Modification_Power.o because of Only_Modification_Power.c # Linking libudf.so because of makefile user.udf udf_names.c udf_names.o Only_Modification_Power.o # linking to ../../src/Only_Modification_Power.c in lnamd64/3ddp_node # building library in lnamd64/3ddp_node # Generating udf_names.c because of makefile Only_Modification_Power.c # Compiling udf_names.o because of udf_names.c # Compiling Only_Modification_Power.o because of Only_Modification_Power.c # Linking libudf.so because of makefile user.udf udf_names.c udf_names.o Only_Modification_Power.o You can also see the 'log'-file in the working directory for this compilation history Done. > adjoint/ parallel/ server/ define/ parametric-study/ solve/ display/ plot/ surface/ exit preferences/ turbo-workflow/ file/ print-license-usage views/ mesh/ report/ > /define/user-defined/compiled-functions load "libudf03" hpc2-cn04: Opening library "/home/mus62929/libudf03"... Done. hpc2-cn04: Opening library "/home/mus62929/libudf03"... modification_factor Done. > adjoint/ parallel/ server/ define/ parametric-study/ solve/ display/ plot/ surface/ exit preferences/ turbo-workflow/ file/ print-license-usage views/ mesh/ report/ > /define/phases/set-domain-properties/interaction-domain/forces/drag yes air-water: tomiyama no data required. yes Drag Factor air-water: user-defined no data required. Error at host: Set_Property: null user-defined-function name "modification_factor::libudf03" invalid command ["modification_factor::libudf03"] Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed. > Halting due to end of file on input. Auto-Transcript Stop Time: 17:19:20, 27 Nov 2024 Total Transcript Time: 0 Minute 23 Second. Automatic transcript closed. |
UDF problem for Population balance model | Amir.11 | Fluent UDF and Scheme Programming | 6 | May 30, 2022 05:36 |
UDF weird problem | Sunmax | Fluent UDF and Scheme Programming | 2 | June 26, 2019 22:48 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
Problem running fluent with udf on supercomputer(batch system) | Sept24 | Fluent UDF and Scheme Programming | 3 | October 15, 2015 13:50 |
Problem running OF on cluster | Rebecca513 | OpenFOAM Running, Solving & CFD | 14 | August 26, 2012 18:09 |
