November 27, 2024, 13:42 |
2D dynamic mesh UDF with deforming geometry
Kamil
I'm trying to replicate a dynamic mesh that was described in a research paper for a two-roller peristaltic pump, I've included a sketch of the deformation of the geometry and the geometry in general. The paper states that a UDF was used to recalculate the boundaries of the mesh at every time step according to a set of equations relating the boundary geometry to the dynamic position of the rollers, but neither the C code for the UDF or the implementation approach were provided. Any pointers where to get started with tackling this kind of mesh would be much appreciated, I'm relatively new to using Fluent but would like to learn more. Any input would be much appreciated, thank you in advance. |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
Dynamic mesh using UDF and layering method - no dynamic mesh zones to display error | HootanRahimi | Fluent UDF and Scheme Programming | 3 | May 7, 2019 13:03 |
UDF: Have 3 dynamic mesh regions working well in 2D, but not in 3D | gabriel09 | Fluent UDF and Scheme Programming | 1 | May 12, 2016 07:06 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
dynamic mesh udf sample | wlt_1985 | FLUENT | 0 | April 11, 2011 00:36 |
