November 18, 2024, 23:52 |
UDF parallelization issue
ttg
Dear all
My code runs well in serial mode, while after parallelization, the solver freeze after clicking on calculation. Here are the codes: #include "udf.h" #include <stdio.h> #include <winsock2.h> #include <winsock.h> #pragma comment(lib,"ws2_32.lib") // Fluent sends this array double send_data[4] = {500.0, 500.0, 500.0, 500.0}; double recvbuf[4] = {0.0}; // Make recvbuf global double fluentUDP1(double senddata[]) // Send array { Message("fluentUDP called with send_data = [%f, %f, %f, %f]\n", senddata[0], senddata[1], senddata[2], senddata[3]); // Initialize Winsock WSADATA wsaData; if (WSAStartup(MAKEWORD(2,2), &wsaData) != 0) { Message("WSAStartup failed.\n"); return -1; } Message("WSAStartup successful.\n"); // Create socket SOCKET sockfd = socket(AF_INET, SOCK_DGRAM, 0); if (sockfd == INVALID_SOCKET) { Message("Socket creation failed. Error code: %d\n", WSAGetLastError()); WSACleanup(); return -1; } Message("Socket created successfully.\n"); // Bind to a local port (ensure it's not in use) struct sockaddr_in local_addr; memset(&local_addr, 0, sizeof(local_addr)); local_addr.sin_family = AF_INET; local_addr.sin_addr.s_addr = inet_addr("127.0.0.1"); local_addr.sin_port = htons(8111); // if (bind(sockfd, (struct sockaddr*)&local_addr, sizeof(local_addr)) == SOCKET_ERROR) { Message("Bind failed with error code: %d\n", WSAGetLastError());//数值正常时可忽略报错,调试使用 closesocket(sockfd); WSACleanup(); return -1; } Message("Bind successful on 127.0.0.1:%d.\n", ntohs(local_addr.sin_port)); // Set up the remote address (MATLAB's listening port) struct sockaddr_in sock_addr; memset(&sock_addr, 0, sizeof(sock_addr)); sock_addr.sin_family = AF_INET; sock_addr.sin_port = htons(4911); // MATLAB's LocalPort sock_addr.sin_addr.s_addr = inet_addr("127.0.0.1"); // Set receive timeout int timeout = 60000; // milliseconds if (setsockopt(sockfd, SOL_SOCKET, SO_RCVTIMEO, (const char*)&timeout, sizeof(timeout)) == SOCKET_ERROR) { Message("Failed to set socket receive timeout. Error code: %d\n", WSAGetLastError()); closesocket(sockfd); WSACleanup(); return -1; } Message("Receive timeout set to %d ms.\n", timeout); // Send data to MATLAB int dataSize = sizeof(double) * 4; // Size of data to send/receive if (sendto(sockfd, (char *)senddata, dataSize, 0, (struct sockaddr*)&sock_addr, sizeof(sock_addr)) == SOCKET_ERROR) { Message("sendto failed. Error code: %d\n", WSAGetLastError()); closesocket(sockfd); WSACleanup(); return -1; } Message("senddata sent to MATLAB.\n"); // Receive data from MATLAB if (recvfrom(sockfd, (char *)recvbuf, dataSize, 0, NULL, NULL) == SOCKET_ERROR) { Message("recvfrom failed. Error code: %d\n", WSAGetLastError()); closesocket(sockfd); WSACleanup(); return -1; } Message("recvbuf = [%f, %f, %f, %f] received from MATLAB.\n", recvbuf[0], recvbuf[1], recvbuf[2], recvbuf[3]); // Clean up closesocket(sockfd); WSACleanup(); Message("fluentUDP completed successfully.\n"); } DEFINE_EXECUTE_AT_END(get_array_from_fluent) { const char *report_names[4] = {"h1", "h2", "h3", "h4"}; int nrOfvalues; real *values; int *ids; int index; int rv; #if RP_HOST for (int i = 0; i < 4; i++) { const char *report_name = report_names[i]; /* First call to get number of values */ rv = Get_Report_Definition_Values(report_name, 1, &nrOfvalues, NULL, NULL, NULL); if (rv == 0 && nrOfvalues > 0) { /* Allocate memory */ values = (real*) malloc(sizeof(real) * nrOfvalues); ids = (int*) malloc(sizeof(int) * nrOfvalues); if (values == NULL || ids == NULL) { Message("Memory allocation failed.\n"); if (values) free(values); if (ids) free(ids); return; } /* Second call to get values */ rv = Get_Report_Definition_Values(report_name, 1, NULL, values, ids, &index); if (rv != 0) { Message("Error retrieving report '%s'. rv = %d\n", report_name, rv); free(values); free(ids); return; } send_data[i] = values[0]; // Assuming we want the first value Message("send_data[%d] = %f from report '%s'.\n", i, send_data[i], report_name); free(values); free(ids); } else { // Handle error Message("Failed to retrieve report '%s'. rv = %d\n", report_name, rv); } } fluentUDP1(send_data); // Call the function to send and receive data #endif host_to_node_real(recvbuf,4);//received a fatal signal (SEGMENTATION VIOLATION) if removed } / DEFINE_PROFILE(set_heat_flux1, thread, position) { host_to_node_real_1(recvbuf[0]); #if RP_NODE face_t f; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = recvbuf[0]; } end_f_loop(f, thread) #endif } DEFINE_PROFILE(set_heat_flux2, thread, position) { host_to_node_real_1(recvbuf[1]); #if RP_NODE face_t f; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = recvbuf[1]; } end_f_loop(f, thread) #endif } DEFINE_PROFILE(set_heat_flux3, thread, position) { host_to_node_real_1(recvbuf[2]); #if RP_NODE face_t f; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = recvbuf[2]; } end_f_loop(f, thread) #endif } DEFINE_PROFILE(set_heat_flux4, thread, position) { host_to_node_real_1(recvbuf[3]); #if RP_NODE face_t f; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = recvbuf[3]; } end_f_loop(f, thread) #endif } If host_to_node_real(recvbuf,4) is removed, the ncortex received a fatal signal (SEGMENTATION VIOLATION). Any suggestion would be helpful |
fluent, parallelization, udf |
reaction UDF hooking issue !!! | shafi_10 | FLUENT | 0 | May 14, 2023 06:29 |
UDF Parabolic 2D Velocity Profile Issue | chrislyn | FLUENT | 2 | December 11, 2018 13:11 |
UDF issue | Oula | FLUENT | 2 | November 28, 2018 10:11 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
Vibromixed 2d UDF loading issue | carteblanche | Main CFD Forum | 0 | May 23, 2011 15:42 |
