November 18, 2024, 00:39 |
udf code to update lengths
Camila Solano
Rep Power: 2 |
hi, I'm struggling writing a udf code that will update the lengths section of a thermosyphon based on the calculated heat transfer value. I'm using the execute_at_end function. any recommendation on how to calculate heat transfer on a solid 2d domain on the y axis with a convective boundary condition. and based on the heat transfer value check the boundary faces of the boundary thread, store the values of the faces that belong to each section based on the heat transfer value, and used this values to calculate thermal resistance. and repeat this process iteratively until the top of the thermosyphon reaches a certain value. transient conditions.
fluent - udf, heat transfer in fluent, udf code |
UDF Code doesn't work | force_95 | FLUENT | 7 | October 30, 2019 01:19 |
Urgent help for UDF Code needed | force_95 | FLUENT | 2 | October 25, 2019 08:35 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 03:48 |
UDF code for concentration distribution | szw_china | Fluent UDF and Scheme Programming | 0 | July 22, 2012 22:35 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 16:56 |
