UDF to vary turbulence intensity over specific number of time steps
Old   October 19, 2024, 00:02
Red face UDF to vary turbulence intensity over specific number of time steps
Anupam Krishnan
yujin_cfd is on a distinguished road
Hi everyone,
I am trying to simulate airflow over an airfoil using unsteady RANS, I am employing a realizable k epsilon model with Menter-Lechner wall treatment. The Reynolds number is 100000. This model gave me better results of lift and drag ratio for validation compared with k-w SST model and I am relying on this particular model.
my simulation has 150 timesteps with 0.1s step size, thus simulating the flow over 15s. I implemented a UDF to vary the k and epsilon parameters over each time step to note the effect of varying turbulence intensity.
I did specify a fixed turbulence intensity for each interval of time. That is 0 to 1s, 1 to 2s, and so on. It recalculates the k and epsilon and varies it during the simulation. My input intensity values followed an upward trend, but after running the simulation it is showing a downward trend. But both follow the same distribution or curve pattern, only the slope is opposite for the trend. I expected or inputted a positive slope but got a negative one.
Does it mean that with each time step, the flow determines the next k and epsilon values to be ste? Can anyone help me with this?
Thanks in advance.
yujin_cfd is offline   Reply With Quote
k epsilon, turbulence intensity, udf
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
