Segmentation fault using F_FLUX in DEFINE_DPM_SOURCE
Old   October 16, 2024, 10:56
Default Segmentation fault using F_FLUX in DEFINE_DPM_SOURCE
Paulo SPS is on a distinguished road
Hi there,
I have a UDF that defines particle source terms in Fluent 17 using DEFINE_DPM_SOURCE with the pressure-based solver.
I need to get the mass flow into the cell containing the particle for this calculation.
I tried using F_FLUX but I keep getting a segmentation fault error, is the mass flow not stored for faces of cells?
The relevant code that causes the crash (if I remove the "f_flow = F_FLUX(f,f_t);" line it doesn't crash):
DEFINE_DPM_SOURCE(Source, c, t, S, strength, p)
    Thread*f_t;
    face_t f;
    int n;
    real f_flow;
    c_face_loop(c, t, n)
            f = C_FACE(c,t,n);
            f_t = C_FACE_THREAD(c,t,n);
Paulo SPS is offline   Reply With Quote
particle, segmentation fault, udf
'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing jaymeen721 OpenFOAM Running, Solving & CFD 1 April 10, 2023 20:17
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
