Built-in compiler doesn't create libudf.dll
Old   October 16, 2024, 02:56
Default Built-in compiler doesn't create libudf.dll
Sergey Chepkasov
Sergey Ch. is on a distinguished road
Hi! Fluent Built-in Compiler doesn't create libudf.dll. Folders (src and win64) are created, but they haven't libudf.dll. What may be wrong? Fluent 2022 R1. UDF is from a tutorial.
Sergey Ch. is online now   Reply With Quote
Old   October 18, 2024, 06:21
Sergey Chepkasov
This problem is solved. Working with .exe files was blocked. The System administrator has unblocked rights on the computer and the problem has gone.
Old   Yesterday, 20:20
Linas is on a distinguished road
Hi Sergey,
I don't see a libudf.dll in the libudf folder. I do see src and win64. Is libudf.dll created once the fluent simulation runs or immediately after the libudf folder is created?
Thanks
Linas is online now   Reply With Quote
Old   Today, 00:19
Sergey Chepkasov
Originally Posted by Linas View Post
Hi Sergey,
Thanks
Hello. libudf.dll is created after compilation of an UDF (Functions->Compiled...->Build). It needs to be compiled once. Closing Fluent doesn't remove the libudf folder and its content.
Old   Today, 08:31
Hi Sergey, Thanks for the comments. I am getting a warning upon compiling my UDF with the built-in compiler.
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "C:\Users\....\libudf\win64\3ddp_host\SConstru ct", line 20, in <module>
Compiler path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin \clang-cl
Linker path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin \lld-link
After compiling, I click load and then initialize and run the simulation. Then I get a fatal error:
Node 1: Process 6996: Received signal SIGSEGV.
Node 2: Process 27464: Received signal SIGSEGV.
Node 0: Process 26448: Received signal SIGSEGV.
Node 3: Process 10824: Received signal SIGSEGV.
Error in the fluent (fl) process : ended abnormally
Other than checking Setup Compilation Environment for UDF in Fluent Launcher do I need to anything else. Thanks.
built-in compiler, libudf.dll
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 01:01
Parallel Build on macOS High Sierra - error: C++ compiler cannot create executables Kit62 SU2 Installation 2 March 27, 2018 10:46
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
create screw in CFX built methee CFX 1 July 8, 2003 23:28
