Error at host: open_udf_library: couldn't get udf_data |
October 10, 2024, 01:57 |
Sergey Chepkasov
Rep Power: 2 |
Hello everyone. I try to use an UDF for Dynamic Mesh (Rigid Body) in Fluent 2022R1.
I click on Functions->Compiled...->Add (Source Files), I add my UDF file (.c), check Use Built-in Compiler-> Build. Console outputs Done. In the working directory libudf folder are created. I click on Load. Console outputs: Error at host: open_udf_library: couldn't get udf_data ?? ??????? ????????? ?????????. Compute processes interrupted. Processing can be resumed. Error: EOF in string read Error Object: () What could be the problem? Thanks for the answers. |
couldn't get udf_data, error at host, udf |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 04:46 |
Host Node Allocation (-ssh and -cx) on Linux HPC | bloodflow | FLUENT | 3 | October 10, 2019 11:46 |
CFX parallel computing questions | w784370882 | CFX | 3 | January 1, 2019 01:40 |
Problem to run simpleFoam using qsub? | be_inspired | OpenFOAM | 1 | December 22, 2015 13:53 |
[OpenFOAM] Color display problem to view OpenFOAM results. | Sargam05 | ParaView | 16 | May 11, 2013 01:10 |
