Yesterday, 05:43 |
Udf sdof
I´m trying to simulate the flow over a circular cylinder that is free to vibrate in both the direction, I´m using this UDF : #include "udf.h" DEFINE_SDOF_PROPERTIES(stage, prop, dt, time, dtime) { Thread *t; Domain *d = Get_Domain(1); real cg[3], vel[3]; // Arrays to store center of gravity position and velocity real mass = 0.03575; real f = 10.25; real wn = 2 * M_PI * f; real z = 0; // Introduce a small damping factor real k = 148.28; real c = 2 * mass * wn * z; // Thread pointer for which this motion is defined t = DT_THREAD(dt); // Set SDOF properties prop[SDOF_MASS] = mass; prop[SDOF_ZERO_TRANS_Z] = TRUE; prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; prop[SDOF_ZERO_ROT_Z] = TRUE; // Get center of gravity position and velocity cg[0] = DT_CG(dt)[0]; // x-direction cg[1] = DT_CG(dt)[1]; // y-direction cg[2] = DT_CG(dt)[2]; // z-direction vel[0] = DT_VEL_CG(dt)[0]; // x-direction vel[1] = DT_VEL_CG(dt)[1]; // y-direction vel[2] = DT_VEL_CG(dt)[2]; // z-direction // Calculate loads in y direction with damping prop[SDOF_LOAD_F_X] = -k * cg[0]; prop[SDOF_LOAD_F_Y] = -k * cg[1]; // Open file for appending FILE *fout = fopen("motion_x_direction01.txt", "a"); if (fout == NULL) { Message("Error opening file.\n"); return; } // Write data into file fprintf(fout, "%g %g %g %g %g\n", time, cg[0], cg[1], vel[0], vel[1]); // Close file if (fclose(fout) != 0) { Message("Error closing file.\n"); } } The UDF is compiled and loaded correctly and it seems to be working, however, the results of displacement I´m getting are much smaller than the reference values, Does anyone have any idea why this is occurring? |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 02:18 |
can anyone help me about the udf of dynamic contact angle in FLUENT? | Albert Lee | FLUENT | 0 | July 1, 2018 08:21 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 12:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
