Today, 05:18 |
Computing the divergence of a vector
Rep Power: 2 |
I'd like to compute the divergence of a vector for use in a source term. Suppose that it takes the form:
where is some constant and is a user-defined scalar (so I have access to its gradient via C_UDSI_G). I know it is possible to get the divergence by specifying each component of as its own user-defined scalar, using C_UDSI_G to get the correct components , , and then summing them. Surely there must be a better way to do this than specifying three additional user-defined scalars for this purpose alone? |
Computing the heat flux vector in OpenFoam | nikovasi | OpenFOAM Programming & Development | 1 | July 9, 2022 19:22 |
Divergence Problem Conjugated Heat Transfer | Christoph.Ha | FLUENT | 27 | December 5, 2017 10:46 |
Two Phase Flow In Vertical Pipe | stonepreston | FLUENT | 2 | October 31, 2017 08:35 |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 13:15 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
