Laser Melting UDF Heat Source Issue [Fluent Crashing] |
August 12, 2024, 11:39 |
Rakibul Islam Kanak
Rep Power: 2 |
Hello everyone,
I am trying to simulate Selective Laser Melting in Ansys Fluent. Its a two phase problem. So I am using VOF model. my domain dimension is : L = 0.8 mm (X axis) W = 0.2 mm (Y axis) H = 0.28 mm (Z axis) In this domain , I patched the domain ( x = 0.8 mm, y = 0.2 mm , z= 0.2 mm) as solid and the rest is gas. I am trying to model the heat source as surface heat source and place it at x = 0 mm , y = 0.1 mm and z is undefined as I will use if statement to find the interface ( where 0<VOF<1) My UDF code is given below. After Compiling and initialising , when I try to view the user defined volumetric heat source under the contour tab , FLUENT Crashes instantly. I am not sure what went wrong. Yes I also created 5 user defined memory locations. Can anyone help? #include "udf.h" #include "sg_mphase.h" #include "mem.h" #include "sg_mem.h" #include "math.h" #include "flow.h" #include "unsteady.h" #include "metric.h" // Constants #define A 0.4 // Absorption coefficient #define P 200 // Laser power (W) #define R 40e-6 // Spot radius (m) #define v 0.5 // Scan speed of laser (m/s) #define Pi 3.1415926535 // Pi constant #define x0 0.0 // Initial x position of the laser (m) #define y0 0.1e-3 // Initial y position of the laser (m) // UDF for adjusting the gradient heat DEFINE_ADJUST(adjust_gradient_heat, domain) { Thread *t; Thread **pt; cell_t c; int phase_domain_index = 3.0; // thjats my metal domain Domain *pDomain = DOMAIN_SUB_DOMAIN(domain, phase_domain_index); Alloc_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL); Scalar_Reconstruction(pDomain, SV_VOF, -1, SV_VOF_RG, NULL); Scalar_Derivatives(pDomain, SV_VOF, -1, SV_VOF_G, SV_VOF_RG, Vof_Deriv_Accumulate); mp_thread_loop_c(t, domain, pt) if (FLUID_THREAD_P(t)) { Thread *ppt = pt[phase_domain_index]; begin_c_loop(c, t) { C_UDMI(c, t, 0) = C_VOF_G(c, ppt)[0]; C_UDMI(c, t, 1) = C_VOF_G(c, ppt)[1]; C_UDMI(c, t, 2) = C_VOF_G(c, ppt)[2]; C_UDMI(c, t, 3) = sqrt(C_UDMI(c, t, 0) * C_UDMI(c, t, 0) + C_UDMI(c, t, 1) * C_UDMI(c, t, 1) + C_UDMI(c, t, 2) * C_UDMI(c, t, 2)); // Magnitude of gradient of volume fraction } end_c_loop(c, t) } Free_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL); } // UDF for defining the heat source DEFINE_SOURCE(heat_source, c, t, dS, eqn) { Thread *pri_th; // Gas phase Thread *sec_th; // solid phase real source; real x[ND_ND], time; time = CURRENT_TIME; // Acquire time from Fluent solver C_CENTROID(x, c, t); // Acquire the cell centroid location real T = C_T(c, t); pri_th = THREAD_SUB_THREAD(t, 0); sec_th = THREAD_SUB_THREAD(t, 1); real rho = C_R(c,t); real Cp = C_CP(c,t); real rhom = C_R(c,sec_th); real Cpm = C_CP(c,sec_th); real rhog = C_R(c,pri_th); real Cpg = C_CP(c,pri_th); real factor = (2 * rho * Cp) / (rhom * Cpm + rhog * Cpg); real r = sqrt(pow(x[0] - x0 - v * time, 2.0) + pow(x[1] - y0, 2.0)); if (C_VOF(c, t) > 0.05 && C_VOF(c, t) < 1) { source = ((2 * A * P) / (Pi * R * R)) * exp((-2 * (r * r)) / (R * R))*factor * C_UDMI(c,t,3); dS[eqn] = 0.0; } else { source = 0.0; dS[eqn] = 0.0; } return source; } |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
