Isolate Cells in Layers Based on Height (FLUENT UDF) |
August 8, 2024, 13:34 |
Baptiste Oudon
Good evening, everyone.
I'm currently working on a UDF in ANSYS Fluent to calculate the Longitudinal Length Scale of turbulence, . I'm using the direct integration of correlation functions, which is expressed as: Here, is the longitudinal fluctuating velocity, is the grid spacing along the x-axis, and represents the y-coordinate level at a constant j for , . In other word corespond to every layer of cells in the y directions. With a number of layer The direct integration of correlation functions involves integrating for each layer of y-cells and I already have every value for and So I need to isolate each cell based on its y-layer within a UDF. But am having trouble finding an efficient method to do this. Do you have any ideas on how I can achieve this effectively? My mesh is structural with inflation layer. Thanks for the help. |
August 9, 2024, 08:56 |
Baptiste Oudon
I am also considering integrating over a sphere of radius , where is the turbulent length scale.
Using this method, I would need to isolate all cells within a sphere of radius and . Do you have any ideas on how I can efficiently do this? I was thinking of using a Boolean operation where the volume of the sphere at the current centroid point intersects the cells in the volume inside the `get_domain` function. However, I’m having trouble finding an efficient way to implement this. If you have any suggestions, I would really appreciate it. |
August 23, 2024, 03:56 |
Rep Power: 2 |
I'm having a similar issue, could you please share your workaround?
udf |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 01:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 02:16 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 15:43 |
[snappyHexMesh] Problem airfoil snappyhexmesh add layer | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 1 | May 5, 2017 06:56 |
Problem with entire domain comprised of split hex cells | Arzed23 | Main CFD Forum | 1 | November 8, 2016 00:01 |
