August 1, 2024, 11:45 |
Divergence error with DPM
Anurag Bhattacharjee
Rep Power: 2 |
I am modeling slurry droplet evaporation inside a spray dryer. I have written a UDF which runs perfectly when the 'interaction with continuous phase' option is turned off. But when turned on, I get the following errors, right after injection starts- ... Divergence detected in AMG solver: epsilon Stabilizing species-0 to enhance linear solver robustness. Stabilizing species-0 using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: species-0 Stabilizing species-1 to enhance linear solver robustness. Stabilizing species-1 using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: species-1 Stabilizing temperature to enhance linear solver robustness. Stabilizing temperature using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: temperature Divergence detected in AMG solver: x-momentum Divergence detected in AMG solver: y-momentum Divergence detected in AMG solver: z-momentum Divergence detected in AMG solver: pressure correction Divergence detected in AMG solver: k Divergence detected in AMG solver: epsilon Divergence detected in AMG solver: species-0 Divergence detected in AMG solver: species-1 ... Error at Node 11: floating point exception Error at Node 9... ... I have tried reducing the URF for all above, set methods to first order upwind and also reducing the number of streams, but the errors persists. Any pointers on how to fix this issue would be greatly appreciated. |
divergence amg solver, dpm in fluent, error #f |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 8, 2021 00:17 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
