Fenil Parmar
Rep Power: 0 ![]() |
I am new to UDF and I need help me with a problem. Thanks in advance. So I want to simulate an acoustic wave on a flat plate. but there is no equation that can be used so I have to use UDF. the equation are in the picture and with respect to those equations I want to give value of the 4 variable purturbation values and solve (u, v, P, and rho) on each mesh nodes for the solution. But I dont know how can I implement them on the whole mesh. the code for UDF I have written is only for the boundary condition.(code is below attached for the reference.) also H_c_real, dH_c_real, H_c_imag, and dH_c_imag variables are heun function which varies with y coordinate. I have written only 3 for only the code to work but originallly and the array values of them are calculated for each mesh node with the help of MATLAB code. ********EQUATION********** Screenshot 2024-07-15 181737.png *********UDF CODE********** #include "udf.h" #include <math.h> #include <complex.h> double M = 0.5; double omega = 5.118277; double P = 101325; static double H_c_real[] = {0.24509769, 0.245235439, 0.245373191}; static double H_c_imag[] = {-0.381717036, -0.381763624, -0.381810167}; static double dH_c_real[] = {1.073832121, 1.074074661, 1.074317076}; static double dH_c_imag[] = {-0.363362371, -0.363084281, -0.362806137}; static int array_size = sizeof(H_c_real) / sizeof(double); // Assuming all arrays have the same size /******************** X - VELOCITY PROFILE ********************/ DEFINE_PROFILE(x_velocity, thread, i) { real x[ND_ND]; double y; double theta; double eta; face_t f; double alpha = 2; double current_time; double eta_prime; current_time = CURRENT_TIME; double x_vel = 1700; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; theta = -pow(M, 2) * pow(2 - omega, 2) + pow(2, 2); eta = creal(_Cmulcc(_Cbuild(0.0, M * 2 * exp(-y)), _Cbuild(0.0, 1.0))) * cos(pow(theta, 0.5) * y); eta_prime = -M * exp(-y) - sqrt(theta); /* Calculate the derivative of eta with respect to y */ double denominator = M * M * (omega - alpha + alpha * exp(-y)); double inner_expression = (alpha / denominator) - (eta_prime * exp(-y) / (denominator * denominator)); // int index = (int)(y / (1.0 / (array_size - 1))); // Assuming y ranges from 0 to 1 // if (index < 0) index = 0; // if (index >= array_size) index = array_size - 1; // _Dcomplex H_c = _Cbuild(H_c_real[index], H_c_imag[index]); // _Dcomplex dH_c = _Cbuild(dH_c_real[index], dH_c_imag[index]); _Dcomplex H_c = _Cbuild(H_c_real[1], H_c_imag[1]); _Dcomplex dH_c = _Cbuild(dH_c_real[1], dH_c_imag[1]); _Dcomplex complex_value = cexp(_Cbuild(0.0, -omega * current_time)); _Dcomplex result = _Cmulcc(_Cbuild(eta, 0.0), complex_value); F_PROFILE(f, thread, i) = x_vel + creal(result) * (creal(_Cmulcc(H_c, _Cbuild(inner_expression, 0.0))) + creal(_Cmulcc(dH_c, _Cbuild((alpha * exp(-2 * y)) / (M * M * denominator * denominator * (alpha - omega)), 0.0)))); } end_f_loop(f, thread) } /******************** Y - VELOCITY PROFILE ********************/ DEFINE_PROFILE(y_velocity, thread, i) { real x[ND_ND]; double y; double theta; double eta; face_t f; double alpha = 2; double OMEGA = 5.118277; double t; double eta_prime; t = CURRENT_TIME; double y_vel = 0; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; theta = -pow(M, 2) * pow(2 - omega, 2) + pow(2, 2); eta = creal(_Cmulcc(_Cbuild(0.0, M * 2 * exp(-y)), _Cbuild(0.0, 1.0))) * cos(pow(theta, 0.5) * y); eta_prime = -M * exp(-y) - sqrt(theta); double denominator = M * M * (omega - alpha + alpha * exp(-y)); _Dcomplex Hc = _Cbuild(H_c_real[1], H_c_imag[1]); ////Hc = Hc_re[cell_index]; _Dcomplex Hc_prime = _Cbuild(dH_c_real[1], dH_c_imag[1]); ////Hc_prime = Hc_prime_re[cell_index]; _Dcomplex complex_value = _Cmulcc(_Cmulcc(cexp(_Cbuild(eta, 0.0)), cexp(_Cbuild(0.0, alpha * x[0] - OMEGA * t))), _Cbuild((eta_prime * creal(Hc) - (alpha * exp(-y) / (alpha - OMEGA)) * creal(Hc_prime)) / (denominator), (eta_prime * cimag(Hc) - (alpha * exp(-y) / (alpha - OMEGA)) * cimag(Hc_prime)) / denominator)); F_PROFILE(f, thread, i) = y_vel + creal(complex_value); //F_PROFILE(f, thread, i) = cexp(eta) * cexp(I * (alpha * x - OMEGA * t)) * (eta_prime * Hc - (alpha * exp(-y) / (alpha - OMEGA)) * Hc_prime) / (I * M * M * (OMEGA - alpha + alpha * exp(-y))); } end_f_loop(f, thread) } /******************** DENSITY PROFILE ********************/ DEFINE_PROPERTY(Density_profile, thread, i) { real x[ND_ND]; /* this will hold the position vector */ real y; double theta; double eta; face_t f; double alpha = 2; double rho = 1.125; double C = 1; _Dcomplex rho_prime; real t = CURRENT_TIME; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; theta = -pow(M, 2) * pow(2 - omega, 2) + pow(2, 2); eta = creal(_Cmulcc(_Cbuild(0.0, M * 2 * exp(-y)), _Cbuild(0.0, 1.0))) * cos(pow(theta, 0.5) * y); _Dcomplex Hc = _Cbuild(H_c_real[1], H_c_imag[1]); rho_prime = _Cmulcc(_Cmulcc(_Cbuild(C, 0.0), cexp(_Cbuild(eta, 0.0))), _Cmulcc(cexp(_Cbuild(0.0, alpha * x[0] - omega * t)), Hc)); F_PROFILE(f, thread, i) = rho + creal(rho_prime); } end_f_loop(f, thread) } /******************** PRESSURE PROFILE ********************/ DEFINE_PROFILE(Pressure_profile, thread, i) { real x[ND_ND]; /* this will hold the position vector */ real y; double theta; double eta; face_t f; double alpha = 2; double rho = 1.125; double C = 1; _Dcomplex rho_prime; real t = CURRENT_TIME; double Pressure = 101325; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; theta = -pow(M, 2) * pow(2 - omega, 2) + pow(2, 2); eta = creal(_Cmulcc(_Cbuild(0.0, M * 2 * exp(-y)), _Cbuild(0.0, 1.0))) * cos(pow(theta, 0.5) * y); _Dcomplex Hc = _Cbuild(H_c_real[1], H_c_imag[1]); rho_prime = _Cmulcc(_Cmulcc(_Cbuild(C, 0.0), cexp(_Cbuild(eta, 0.0))), _Cmulcc(cexp(_Cbuild(0.0, alpha * x[0] - omega * t)), Hc)); F_PROFILE(f, thread, i) = Pressure + 1.4 * creal(rho_prime); } end_f_loop(f, thread) } |
acoustic, fluent, mesh 2d, udf |
Creating cfd solver using udf | durg | Fluent UDF and Scheme Programming | 2 | October 15, 2018 06:33 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
Creating UDF and loading it in ANSYS Fluent | singingfish | Fluent UDF and Scheme Programming | 1 | February 7, 2014 12:10 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
