UDF describes the pressure drop in the pressure loss region
Old   July 5, 2024, 09:51
Default UDF describes the pressure drop in the pressure loss region
Williams
gearman is on a distinguished road
Dear friends!
I have a region of high pressure loss in my piping system.I want to insert a region similar to porous media in the piping system grid.The pressure loss in this region is equal to the square of the mass flow rate.How do I write UDF in this region.The inlet of the piping is the mass flow inlet and the outlet is the pressure outlet.Thank you in advance!
gearman is offline   Reply With Quote
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 13 June 23, 2024 14:12
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Calculating Pressure Drop by UDF wanghaojie Fluent UDF and Scheme Programming 0 January 8, 2012 12:53
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
