May 15, 2024, 02:00 |
Divergence detected in AMG solver: uds-0
mary
Rep Power: 3 |
Hi all,
I am simulating a case with compressible flow. I am also using udf for scalar transport equation. I have run iterations beforehand, with the uds-0 equation off, to get a converged solution before enabling the uds-0. Once the solution is converged by checking the mass flux and heat flux imbalances, I turned on the calculations of uds-0 in the same case file. The output text in the console immediately printed out "Divergence detected in AMG solver: uds-0". I have reduced the under-relaxation factor for the uds-0 to 0.1, and still the error persists. I also tried changing it to coupled solver and playing around with the multigrid solver, but the error is still there. My mesh is not the best but is having > 0.1 as the minimum orthogonal quality. I am stuck in this problem for quite some time now. Any suggestions are welcome. Thanks. |
divergence detected in AMG solver: momentum | sudhakar | FLUENT | 41 | January 23, 2024 03:56 |
Divergence detected in AMG solver | Rahmani_Zakaria | Fluent Multiphase | 4 | January 11, 2023 15:09 |
Divergence detected in AMG solver: pressure correction | xinquanzhoucn | FLUENT | 5 | July 21, 2014 04:49 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
