Fluent source dependent from time and temperature problem |
April 16, 2024, 10:57 |
Hi everybody, I am new to fluent UDFs. My job is to define a heat source in a battery volume, extracting the data from a table which is then divided into time intervals in order to be more accurate when approximating this source data into a polynomial.
To define the source I set the UDF into time intervals using an if else if cycle. I obtained this UDF where in the first part I set an outside temperature monitor, then i set the source function. The problem I face is that starting from the 3rd interval the temperature has wrong values, increasing in an exagerated way. Where am I wrong?? Thanks in advance to anybody who will answer --------------------------------------------------------------- --------------------------------------------------------------- #include "udf.h" real area_tot = 0; real tsum = 0; int i = 0; FILE *qvol; DEFINE_EXECUTE_AT_END(average_temp) { Domain *d; face_t f; real A[ND_ND]; real temper; real area; real tavg_real; int ID = 10000; int cell_id = 9995; Thread *t; cell_t c; d = Get_Domain(1); t = Lookup_Thread(d,ID); c = Lookup_Thread(d,cell_id); begin_f_loop(f,t) /*t identificato sopra*/ { i++; F_AREA(A,f,t); area = NV_MAG(A); temper = F_T(f,t); area_tot += area; tsum += temper; } end_f_loop(f,t) tavg_real = F_UDMI(f,t,0) = tsum /( i * area_tot); } DEFINE_SOURCE(heat_source_else,c,t,ds,eqn) { real time = CURRENT_TIME - 20; real source; face_t f; real tavg = F_UDMI(f,t,0); begin_c_loop(c, t) /* loops over faces in a face thread */ { if (time <= 80) { source = 1.293740341969334e+04 + 1.155185358507742e+03 * time - 2.379268980753591e+03 * tavg - 5.649970340744653e+01 * pow(time, 2) - 1.976396708411658e+01 * time * tavg + 1.752096173848799e+02 * pow(tavg, 2) + 1.339829964037692e+00 * pow(time, 3) + 6.257563010711130e-01 * pow(time, 2) * tavg + 2.835527245363084e-01 * time * pow(tavg, 2) - 6.547212742496961e+00 * pow(tavg, 3) - 1.372517572726491e-02 * pow(time, 4) - 1.426208700704884e-02 * pow(time, 3) * tavg + 7.545497774402981e-03 * pow(time, 2) * pow(tavg, 2) - 1.092233515427415e-02 * time * pow(tavg, 3) + 1.160103394950499e-01 * pow(tavg, 4) + 5.145914794527816e-05 * pow(time, 5) + 8.069157261724937e-05 * pow(time, 4) * tavg - 1.157443550354187e-05 * pow(time, 3) * pow(tavg, 2) - 5.689098345730353e-05 * pow(time, 2) * pow(tavg, 3) + 1.082901372206399e-04 * time * pow(tavg, 4) - 7.861770488630989e-04 * pow(tavg, 5); } else if (time > 80 && time <= 1560) { source = 3.572353433966986e+04 + 1.504725560307832e+01 * time - 4.305741709837774e+03 * tavg - 3.007670621456760e-02 * pow(time, 2) + 1.859195732546453e-01 * time * tavg + 2.884657370568110e+02 * pow(tavg, 2) + 3.713674310102147e-05 * pow(time, 3) - 1.526458940539785e-04 * pow(time, 2) * tavg - 2.028220731966852e-03 * time * pow(tavg, 2) - 1.027481185720795e+01 * pow(tavg, 3) - 1.887603697296835e-08 * pow(time, 4) - 3.512652110128167e-07 * pow(time, 3) * tavg + 1.883092302028152e-05 * pow(time, 2) * pow(tavg, 2) - 2.304064723465128e-04 * time * pow(tavg, 3) + 1.783596586083186e-01 * pow(tavg, 4) + 2.833434262501215e-12 * pow(time, 5) + 2.156423741401386e-10 * pow(time, 4) * tavg - 6.701362245916121e-09 * pow(time, 3) * pow(tavg, 2) - 3.217842108648160e-08 * pow(time, 2) * pow(tavg, 3) + 2.145009790443847e-06 * time * pow(tavg, 4) - 1.197286765135389e-03 * pow(tavg, 5); } else if (time > 1560 && time <= 1900) { source = 9.531011471749905e+06 - 3.363916338547694e+04 * time + 3.331256457378804e+05 * tavg + 4.503208628648606e+01 * pow(time, 2) - 6.947718183443817e+02 * time * tavg - 1.327004912238531e+03 * pow(tavg, 2) - 2.816703307340135e-02 * pow(time, 3) + 3.968045984613180e-01 * pow(time, 2) * tavg + 9.723870943634603e+00 * time * pow(tavg, 2) - 1.288886842505804e+02 * pow(tavg, 3) + 7.980268082497785e-06 * pow(time, 4) + 1.071912314326167e-05 * pow(time, 3) * tavg - 1.263872195054982e-02 * pow(time, 2) * pow(tavg, 2) + 2.532290242144435e-01 * time * pow(tavg, 3) - 1.454134052575408e+00 * pow(tavg, 4) - 7.470693278106096e-10 * pow(time, 5) - 4.531503740743649e-08 * pow(time, 4) * tavg + 4.756817026485388e-06 * pow(time, 3) * pow(tavg, 2) - 1.298019551282745e-04 * pow(time, 2) * pow(tavg, 3) + 1.595715190293275e-03 * time * pow(tavg, 4) - 8.289107283507393e-03 * pow(tavg, 5); } else if (time > 1900 && time <= 2650) { source = 1.334556967592067e+05 + 1.364202357062836e+03 * time - 1.604028456958695e+05 * tavg - 2.946727748042327e+00 * pow(time, 2) + 3.266616064310093e+02 * time * tavg - 1.322310937086781e+03 * pow(tavg, 2) + 2.432675706044515e-03 * pow(time, 3) - 2.982415242081833e-01 * pow(time, 2) * tavg + 5.620745389958381e+00 * time * pow(tavg, 2) - 8.724593124214688e+01 * pow(tavg, 3) - 9.268854786566970e-07 * pow(time, 4) + 1.320652320957073e-04 * pow(time, 3) * tavg - 4.858031909644004e-03 * pow(time, 2) * pow(tavg, 2) + 1.155495186556525e-01 * time * pow(tavg, 3) - 7.673718590338964e-01 * pow(tavg, 4) + 1.333096487842449e-10 * pow(time, 5) - 2.162492986745797e-08 * pow(time, 4) * tavg + 1.081528976294556e-06 * pow(time, 3) * pow(tavg, 2) - 2.839762204484407e-05 * pow(time, 2) * pow(tavg, 3) + 1.455524895059615e-04 * time * pow(tavg, 4) + 2.722899274167420e-03 * pow(tavg, 5); } else if (time > 2650) { source = -4.095300318889147e+06 + 7.823847587495723e+03 * time - 1.043765737289807e+05 * tavg - 5.825576421889270e+00 * pow(time, 2) + 1.309094467134265e+02 * time * tavg + 5.390501339365486e+02 * pow(tavg, 2) + 2.146396857180939e-03 * pow(time, 3) - 6.645451890148453e-02 * pow(time, 2) * tavg + 3.745400361652057e-02 * time * pow(tavg, 2) - 2.129175105412379e+01 * pow(tavg, 3) - 3.903416990802825e-07 * pow(time, 4) + 1.446547355408757e-05 * pow(time, 3) * tavg + 4.847441274804268e-05 * pow(time, 2) * pow(tavg, 2) - 3.187304494343842e-03 * time * pow(tavg, 3) + 4.391172638049189e-01 * pow(tavg, 4) + 2.802566549093382e-11 * pow(time, 5) - 1.133194749454201e-09 * pow(time, 4) * tavg - 1.451245741925541e-08 * pow(time, 3) * pow(tavg, 2) + 8.615177289567311e-07 * pow(time, 2) * pow(tavg, 3) - 1.897745223176266e-05 * time * pow(tavg, 4) - 2.495312174754752e-03 * pow(tavg, 5); } ds[eqn] = 0; return source; } end_c_loop(c, t) } |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 10, 2022 00:58 |
Averaging over iterations for steady-state simulation | CFD student | Fluent UDF and Scheme Programming | 8 | September 22, 2022 04:39 |
Slow calculation time on CFD server | killian153 | Hardware | 4 | July 27, 2021 08:28 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
UDF to Define Temperature Dependent Negative Heat Source | ATIKADAR | Fluent UDF and Scheme Programming | 1 | September 23, 2019 04:52 |
