UDF that can get the number of particles passing through a certain interior region
Old   March 6, 2024, 08:56
Default UDF that can get the number of particles passing through a certain interior region
S.J
SunDongYul is on a distinguished road
Hello. I am doing a cyclone DPM simulation with ANSYS FLUENT.
I want to know the number of particles passing through a certain interior surface, but it is a interior surface so I can't set it as a trap.
The equation for the surface is [x]^{2}+[y]^{2}[/math][/math] = 0.0025, 0\leqz\leq0.1.
(Side of a cylinder with radius 0.05, height 0.1)
I wrote code to exclude particles when they enter a certain area.
The UDF code is as follows.
The condition is transient, Steady particle tracking.
#include "udf.h"
#include "math.h"
#include "dpm.h"
DEFINE_DPM_SCALAR_UPDATE(trapp, c, t, initialize, p)
real x[ND_ND]; // Array to store particle positions
real t_r = 0.05; // Radius of reference circle
real h_min = 0; // Minimum height
real h_max = 0.1; // Maximum height
real d_from_center; // Distance between particle and the center of the circle
C_CENTROID(x, c, t); // Get the current particle position
d_from_center = sqrt(x[0] * x[0] + x[1] * x[1]);
if (d_from_center <= t_r && x[2] >= h_min && x[2] <= h_max)
return PATH_ABORT; // Remove particles when they come within range
An error occurs when building udf in FLUENT, but I don't know what the error is.
I also tried using another macro, P_POS(p), to express the position of the particle, but an error still occurred.
Please let me know how I can implement the code.
Other different methods with my code are also okay. Please give me some advice.
Thank you.
SunDongYul is offline   Reply With Quote
Old   March 11, 2024, 15:18
Default Help
Mohammed
mohkh is on a distinguished road
is my code right
#include "udf.h"
#define Beta 60. /*Exit angle of swirler*/
#define PI 3.14159265359
#define WEIGHT 1.e20
DEFINE SOURCE(user swirl, cell, thread, dS, eqn)
real swirl_vel, x[3], y, source;
/*float swirl_vel, x[3], y, source;*/
C_CENTROID(x, cell, thread);
y=x[1];
/* y-coord, radius */
swirl_vel=(C_U(cell, thread))*(tan(Beta*PI/180)); /*swirl vel in cell*/
/* returning the linearized source (see below) */ source=WEIGHT*(swirl vel-C_ SWIRL(cell, thread)); dS[eqn]=-WEIGHT;
return source; }
mohkh is offline   Reply With Quote
use the message in macro DEFINE_PROFILE with parallel processor alireza_T Fluent UDF and Scheme Programming 3 May 11, 2022 03:08
[Other] Equal decomposition of cylindrical fluid domain Sean95 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2019 04:34
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
