March 3, 2024, 20:50 |
Help About a UDF setup
Jishan Ahmed
#include "udf.h"
#include "math.h" #include "sg_udms.h" #define debye 0.001 #define rhomax 0.0008 #define phimax 5000 #define sigma 0.003 #define rholoc 0.5 enum { phi, rho }; enum { Ex, Ey, Fx, Fy, Fm }; DEFINE_ADJUST(udf_adjust, domain) { Thread *t; cell_t c; thread_loop_c(t,domain) { begin_c_loop(c,t) { C_UDMI(c,t,Ex)=-C_UDSI_G(c,t,phi)[0]; C_UDMI(c,t,Ey)=-C_UDSI_G(c,t,phi)[1]; } end_c_loop(c,t) } } DEFINE_SOURCE(rho_source, c, t, dS, eqn) { real source; source=-pow(debye,-2)*C_UDSI(c,t,rho); dS[eqn]=-pow(debye,-2); return source; } DEFINE_SOURCE(X_Source, c, t, dS, eqn) { real Sourcex; Sourcex=-rhomax*phimax*C_UDSI(c,t,rho)*C_UDSI_G(c,t,phi)[0]; dS[eqn]=-rhomax*phimax; C_UDMI(c,t,Fx)=Sourcex; return Sourcex; } DEFINE_SOURCE(Y_Source, c, t, dS, eqn) { real Sourcey; Sourcey=-rhomax*phimax*C_UDSI(c,t,rho)*C_UDSI_G(c,t,phi)[1]; dS[eqn]=-rhomax*phimax; C_UDMI(c,t,Fy)=Sourcey; C_UDMI(c,t,Fm)=sqrt(C_UDMI(c,t,Fx)*C_UDMI(c,t,Fx)+ C_UDMI(c,t,Fy)*C_UDMI(c,t,Fy)); return Sourcey; } DEFINE_PROFILE(rho_profile,thread,i) { float r[3]; float x; real xloc; face_t f; begin_f_loop(f,thread) { F_CENTROID(r,f,thread); xloc = r[0]; F_PROFILE(f,thread,i)=exp(-pow((xloc-rholoc),2)/(2*pow(sigma,2))); } end_f_loop(f,thread) } this is a udf by Modeling of Dielectric-Barrier Discharge Actuator Implementation, validation and generalization of an electrostatic model A. Bouchmal how to implement this on an airfoil (noting its cambered profile) study. Specially the changes in cell zone boundary conditions or any other. I tried my best to my knowledge. |
May 31, 2024, 23:45 |
Yijun Lu
Rep Power: 2 |
I met the same problem. I complied the UDF in fluent, but when I define the number of UDM and UDS, which are 5 and 2 respectively, and x, y momentum in the source term, errors occur after calculation and "fluent process cannot be ...".
June 1, 2024, 14:08 |
Jishan Ahmed
Solved your problem?
June 1, 2024, 21:09 |
Yijun Lu
Rep Power: 2 |
Not yet!
Here are the problems I met. When I complied this UDF in FLUENT successfully, I take the following steps: (1) define the numbers of UDM and UDS, which are 5 and 2 respectively. (2) add the x-momentum and y-mom sources term in cell zone condition the next step is adding the User scalar 0 and 1 with rho_profile and rho_source, which I cannot be sure. Then errors occur after clicking calculation By the way, the author of this UDF uses it to solve the body force of the plasma only, not on airfoil. So may be we can solve the UDF inplementation on plasma firstly, and then on airfoil? |
airfoil, plasma actuator, plasma actuator modeling |
UDF for vapor pressure | anuarun | Fluent UDF and Scheme Programming | 13 | June 23, 2024 13:12 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
Help Parallelizing UDF | AndresC | FLUENT | 0 | February 25, 2010 15:50 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
