February 14, 2024, 12:35 |
Omega wall treatment change via UDF
Rep Power: 13 |
Hello, I work with Fluent and the default treatment at the wall is given by what can be seen in this page. I need to modify the value of the , which according to several papers can be done with a UDF. I have checked the available options in the UDF manual, but didn't find a way. Does anybody here know how this can be done?? Thanks! |
February 27, 2024, 11:41 |
K-Omega UDF - Modelling drag reduction effect by Sharkskin
David Tyrrell
I am trying to achieve the same thing you were. Essentially I need to modify the value of omega at the wall to model the effect of sharkskin riblet drag reduction. Did you ever manage to get a result in the end? Or if anyone else could offer advice that would be great, even if it were to say it is not possible in FLUENT. Regards, David Tyrrell |
March 11, 2024, 05:03 |
Rep Power: 13 |
At the moment I am not actively developing the udf, but the last status is that I could set a constant omega in the whole domain.
I don't manage to fix it only at the first cell adjacent to certain walls... Also managed to calculate the u*, which took me some time because I couldn't obtain the wall shear values of each cell ... |
fluent udf, omega, wall treatment |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
On the LES near wall treatment | huangxianbei | FLUENT | 8 | August 27, 2014 11:13 |
UDF to change BC from Wall to Grid Line | Aaron Smith | FLUENT | 0 | February 21, 2006 09:14 |
