Modeling effect of vapor absorption in energy exchangers
Old   January 25, 2024, 23:47
Default Modeling effect of vapor absorption in energy exchangers
Ali Qasim
Ali_qasim is on a distinguished road
Hi everyone,
I am modeling a membrane energy exchanger for dehumidification of the air in a hot, humid climate. In this energy exchanger system, the air flows on one side of the membrane, and on the other, the liquid desiccant solution flows. Both fluids are separated by the semi-permeable membrane, which allows only moisture transfer but not liquid. I am modeling this system through the ANSYS FLUENT and UDF is used to model moisture transfer through the membrane.
As the moisture transfers through the membrane, it changes phase at the air-liquid solution interface. In ANSYS Fluent, the effect of this temperature change is not considered while solving the energy equation.
How can I include this effect of phase change of vapor (absorption on the solution-air interface) phenomenon on the performance of the system in terms of temperature change of solution and air?
Can I include this effect using Eulerian Wall Film?
Thanks
Ali_qasim is offline   Reply With Quote
Old   February 4, 2024, 08:46
Sebi
bloodflow is on a distinguished road
Originally Posted by Ali_qasim View Post
Hi everyone,
Thanks
Are you sure this energy change is not accounted for within the phase change process? If it is an in-built phase change model in Fluent I'm pretty sure its there.
The energy change would be m_dot*L_V where m_dot is the phase change mass flow rate in kg/m3/s, and L_v is the latent heat of vaporization (or condensation if the mass transfer is gas -> liquid).
You can add this with a DEFINE_SOURCE UDF.
bloodflow is offline   Reply With Quote
Old   February 7, 2024, 14:35
Ali Qasim
Thank you for your response.
I am not using the in-built model of Phase Change ANSYS Fluent.
I am using the UDF for the vapor transfer from one side to another. Once the vapors transfer, they change their phase when they interact with the liquid. I need to tackle this effect of phase change on the temperature of the liquid in which it is absorbing. Your guidance would be a great help for me. Regards
Old   February 7, 2024, 15:41
Sebi
I assume your evaporation/condensation UDF returns the mass flow rate from one phase to the other, and a value of 0 elsewhere.
The temperature change when this phase change occurs from energy being released (condensation) or energy being absorbed (evaporation). The magnitude of this energy is the rate of phase change (kg/s) multiplied by the latent heat of evaporation/condensation (J/kg) for your species
You need to use a DEFINE_SOURCE UDF for this energy being released or absorbed during evaporation/condensation. It loops over all cells, and in cells where no phase change occurs, the value of the source is 0J. In cells where evaporation does occur, a suitable energy source is defined as m_dot*L_V. This will change the local temperature in cells with phase change.
Old   February 7, 2024, 15:51
Sebi
PHP Code:
DEFINE_SOURCE(phase_change_energy,c,t,dS,eqn)
/* Define source UDF's loop over all cells in the domain */
    /* A seperate phase change UDF has calculated the rate of phase change in each cell as m_dot, with units kg/s */
    /* If m_dot > 0 -> Phase change is liquid -> vapour -> Energy is absorbed -> Cell temp decreases */
    /* If m_dot < 0 -> Phase change is vapour to liquid -> Energy is released -> Cell temp increases*/
    /* If m_dot = 0 -> No phase change occured -> No energy is released -> No temperature change */
real energy;
real L_v 2260*1000/* Latent heat of vapourisation of water in J/kg */
energy m_dot*L_V/* Energy source during phase change in J/s */
return energy/* Return value of energy source to cell */
Regarding the energy equation(Internal energy equation) in the sonicFoam solver. applekiller OpenFOAM Programming & Development 4 May 16, 2023 10:52
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 01:15
FSI modeling of a surface effect ship!!! smn CFX 10 January 26, 2010 17:26
Energy source modeling shahpar73 CFX 2 September 23, 2009 08:36
Modeling the Effect of Vortex Generators on Wings Ben Cho FLUENT 0 April 19, 2006 13:19
