Compiler error UDF Fluent
Old   January 11, 2024, 13:20
Default Compiler error UDF Fluent
EmmaKate
emmakateh is on a distinguished road
I am using the x64 Native tools Command Prompt for VS 2017 to build my UDF Library (chapter 5 in the udf manual) I have setup the user_nt.udf in this way:
CSOURCES = $(SRC)magneticfield_w_externalcalcs.c
HSOURCES = $(SRC)header_external_calcs.h
VERSION = 3ddp_node
PARALLEL_NODE = smpi
# Do not change the following line unless externally precompiled objects
# are to be included at the linking stage.
# For example: USER_OBJECTS = my_fortran_funcs.obj
USER_OBJECTS = external_calcs.obj
I put the magneticfield_w_externalcalcs.c and header_external_calcs.h in the ..\..\src folder but when I execute the makefile i get this error:
cl : Command line warning D9024 : unrecognized source file type '..\..\src\header_external_calcs.h', object file assumed
cl : Command line warning D9027 : source file '..\..\src\header_external_calcs.h' ignored
I am not sure why the makefile is ignoring the header but if anyone can help, please let me know!
emmakateh is offline   Reply With Quote
header file, makefile, udf compiler
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Running Fluent from Python: UDF Compilation problems Ames Fluent UDF and Scheme Programming 5 November 16, 2020 07:12
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 01:01
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 14:50
