January 8, 2024, 09:25 |
problem with reading data from txt file
amina
Rep Power: 6 |
hi everyone,
i try to read a file named data.txt that contains the absorption coefficient of gas . for that i wrote 2 UDFs : the 1st : DEFINE_ON_DEMAND for reading a variable 'coef' the 2nd: DEFINE_GRAY_BAND_ABS_COEFF to allocate the coef variable readed previously (from data.txt file) to the absorption coefficient . //////////////////////////****/////////////////////////// DEFINE_ON_DEMAND(lire) { FILE* fp; float coef[5]; int i, j; fp = fopen("C:\\Codes\\ALBDF\\Tables\\data.txt", "r"); for (i = 0; i < 5; i++) { fscanf(fp, "%f", &coef[i]); } fclose(fp); } *********/////********************* DEFINE_GRAY_BAND_ABS_COEFF(abs3, c, t, nb) { float coef[5]; switch (nb) { case 0: abs_coeff = coef[0]; break; case 1: abs_coeff = coef[1]; break; case 2: abs_coeff = coef[2]; break; case 3: abs_coeff = coef[3]; break; case 4: abs_coeff = coef[4]; } return abs_coeff; } /////*************//////// The problem is when i hook the 1st udf(DEFINE_ON_DEMAND) the fluent-window disaper ( fluent window closes spontaneously) i dont found the probleme were is ???? |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 09:27 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
