UDMI doesn't save the right Reynold number value?
Old   December 24, 2023, 08:29
Default UDMI doesn't save the right Reynold number value?
Chhotelal
Chhotelal1234 is on a distinguished road
Dear Expert,
I'm facing confusion regarding the incorrect retrieval of the Reynold number value when saving it in a UDF using UDMI. I've developed a UDF for exchanging properties in multiphase modeling, specifically aiming to save the Reynold number value via UDMI. However, the stored value doesn't appear to be accurate.
The Reynold number equation I'm using is Re = (rho_g * abs_v * dp)/mu_L, where the variables rho_g, abs_v, dp, and mu_L obtain values from the cell.
My attempt to store the Reynold number value in UDMI is as follows:
C_UDMI(c, t_mix, 0) = Re;
I've also experimented with alternative storage locations like (C, t_gas, 0) and (C, t_solid, 0), but the results remain inaccurate. Could you please advise on the possible reasons behind this issue and suggest the correct approach?
Chhotelal1234 is offline   Reply With Quote
Old   December 26, 2023, 03:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check ansys fluent customization manual
2.4.3.3. Example 1 - Custom Drag Law
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
FOAM FATAL IO ERROR:file: unknown YatengQ OpenFOAM Running, Solving & CFD 0 January 31, 2023 08:14
[mesh manipulation] mergeMeshes for more than two fluid domains Vishsel OpenFOAM Meshing & Mesh Conversion 17 May 20, 2019 08:05
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
