Reading the last value (converged one) from the file through UDF
Old   December 13, 2023, 09:24
Default Reading the last value (converged one) from the file through UDF
Zee
ZA
Zee is on a distinguished road
Dear All,
I need to develop a UDF to read converged values (temperature, velocity, etc) from the outlet of system1 and apply these values on the inlet of system2.
In ANSYS FLUENT, I have generated the report definitions of mass-weighted average temperature and velocity at the outlet of system1.
Is there any macro that can be used in UDF to read only the last value (converged) from the file saved through the report definitions?
Your guidance in this regard would be highly appreciated.
Best Regards,
Zee is offline   Reply With Quote
Old   December 15, 2023, 06:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may use macro to execute code whenever you want
DEFINE_ON_DEMAND (your_function_name)
for more information take a look at ansys fluent customization manual
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
