C_VOF_G in three phase model
Old   December 8, 2023, 12:37
Default C_VOF_G in three phase model
cfd_Matrix is on a distinguished road
Hi all,
I am modeling Sun heating oil layer on top of water in three phase vof model (air as primary phase).. the solar flux (w/m2) is incorporated as heat source at the interface for oil vof >=0.5. I using DEFINE ADJUST to store VOF gradiant in C_UDMI; Display C_UDMI shows both interfaces (air/oil and water/oil). when I Run the calculation seem like it don't apply the heat source at all.
my question is why the CUDMI save both interfaces a,d how to force the SOURCE term at the air/oil interface (F(oil) >= 0.5.
Thanks in advance
#include "udf.h"
#include "sg_mphase.h"
#define Sun_flux 1120 /* average solar heat flux on earth surface (W/m2) */
DEFINE_ADJUST(my_adjust, mixture_domain)
int phase_domain_index=0.;
Thread *t;
cell_t c;
mixture_domain= Get_Domain(2);
thread_loop_c (t,mixture_domain)
if (THREAD_STORAGE(t,SV_UDM_I)!=NULL)
begin_c_loop (c,t)
/*To store gradient of volume fraction in a user defined memory*/
C_UDMI(c,t,0)=sqrt((C_VOF_G(c,t)[0])*(C_VOF_G(c,t)[0])+(C_VOF_G(c,t)[1])*(C_VOF_G(c,t)[1]));
end_c_loop (c,t)
DEFINE_SOURCE(heat, cell, mix_th, dS, eqn)
Thread *pri_th, *sec_th;
real source;
pri_th = THREAD_SUB_THREAD(mix_th, 0);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
if (C_VOF(cell,pri_th)>0.05 && C_VOF(cell,pri_th)<0.5)
source= Sun_flux*C_UDMI(cell,mix_th,0);
dS[eqn] = 0.0;
return source;
cfd_Matrix is offline   Reply With Quote
Old   December 10, 2023, 18:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if you defined domain in header
you don't need to reinitialize it
compile code and you will see errors
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 11, 2023, 02:31
Dear AlexanderZ Thank you for your reply, I compilE the UDF, and it compile with no error, the problem i am facing is with DEFINE SOURCE, which describe the absorbed heat at the oil/air interface (heat flux * mag(grad(F)), either it apply the eat source to both interfaces or it does not apply it at all, the problem is with :
how to force the SOURCE term at the air/oil interface and for (F(oil) >= 0.5
any clue on how to solve this problem ?
Old   December 12, 2023, 01:27
Alexander
I can hardly understand what you a talking about
dS[eqn] = 0.0;
return source;
there is no else statement for C_VOF(cell,pri_th)> 0.5 actually
else
return source;
best regards
Old   December 12, 2023, 16:44
dS[eqn] = 0.0;
return source;
else
return source;
Dear AlexanderZ; what i mean by if statament is to force the heat source at the air/oil interface (not oil/water interface ) and it should be applied for cells belong to the interface with F(oil) >= 0.5 / Then the if statemnt should be like this:
if (C_VOF(cell,sec_th)>0.5) /* oil is the first secondary phase*/
dS[eqn] = 0.0;
else
source= 0.0;
dS[eqn] = 0.0;
return source;
Using Fluent VOF and Lee model to simulate mass transfer of two phase Albert Lee FLUENT 1 May 2, 2019 09:01
Transient Phase Change Model: Explodes at low vapor quality evcelica CFX 0 August 28, 2018 11:55
Condensation/Evaporation Model (Phase Change) oliveira1820 CFX 0 May 29, 2018 03:07
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
