Multiple DEFINE_ADJUST in a running time
Old   December 4, 2023, 07:06
Default Multiple DEFINE_ADJUST in a running time
Canh Doan
canh.dv@seoultech.ac.kr is on a distinguished road
Hi everyone,
I am running a problem with 2 DEFINE_ADJUST.
1st DEFINE_ADJUST collects data and assigns it to a global variable array.
2nd DEFINE_ADJUST takes the data from the global variable array and assigns it to fluent.
DEFINE_ADJUST(adjust_absorb_coe_to_global_matrix_bb, d)
	cell_t c;
	Thread *t;
	face_t f;
	real xc[ND_ND];
	real xx, yy;
	int i,j,m,n, count;
	d = Get_Domain(1);
	thread_loop_c(t,d)
			if(THREAD_ID(t) == 2)
				begin_f_loop(f,t)
					F_CENTROID(xc,f,t);
					xx = xc[0];
					yy = xc[1];
					m = (xx+0.05)/0.001;
					n = yy/0.001;
					count = 24*m+n;
					BB[count] = C_ABS_COEFF(c,t);
					printf("Global array BB[%d] = %f\n", count, BB[count]);
			end_f_loop(f,t)
DEFINE_ADJUST(adjust_cal_intensity_depend_on_bb, d)
	int i,j,m,n, count;
	i = 0;
    for(j = 0; j<25; j++)
        AA[24*i+j] = 1000;
        printf("AA[%d] = %f\n", 24*i+j, AA[24*i+j]);
    for(i = 0; i<100; i++)
            if(i == 0)
                AA[24*i+j] = AA[24*i+j];
            else
                AA[24*i+j] = AA[24*(i-1)+j] * (1 - BB[24*(i-1)+j]);
To get the precise result, the first DEFINE_ADJUST must run first and assign all the data to the global variable array, then the second DEFINE_ADJUST will get the data from the global variable array.
I found that these two functions run as follows: ADJUST-1 run, assign ~150 values, and then ADJUST-2 run. This process repeats 17 times.
I cannot understand why this happened. What I expect is ADJUST-1 runs one time, assign 2500 value, and then ADJUST-2 run one time and get data.
canh.dv@seoultech.ac.kr is offline   Reply With Quote
Old   December 5, 2023, 02:22
Canh Doan
The problem is solved.
The loop ran 16 times because I set the parallel solver as 16. After that my system worked well.
define_adjust, loop over cells, udf
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
