Manipulating strings using If/Do Loop in Journal File
Old   November 28, 2023, 00:40
Default Manipulating strings using If/Do Loop in Journal File
veda
saha.vedabit is on a distinguished road
I am trying to write a journal file that can change shadow walls to interior, by the following logic:
if (Wall_name contains the term "shadow")
change Wall to Interior
Is it possible in Scheme to run an If or Do loop based on string name?
Thank you
saha.vedabit is offline   Reply With Quote
command, fluent, journal, scheme, tui
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
