November 25, 2023, 14:45 |
Flapping wing overset mesh for 2 DOF
Raj Kiran
Rep Power: 8 |
Dear All,
I have to perform overset mesh simulation with 2 degrees of freedom (DOF) motion. But the mesh motion is wrong when I run preview mesh motion. However, when I run a 1 DOF motion the meshes are working fine. UDF am using is as follows for 2 DOF and the images are attached of mesh for reference. 1 DOF work good but the deviation of wing from the XZ plane while I am trying to move about the wing tip and about the wing chord it is moving in some different direction. I have given the position of center of gravity in dynamic mesh is the midpoint of wing root(one side of the rectangular wing) #include "udf.h" DEFINE_CG_MOTION(wing_motion, dt, vel, omega, time, dtime) { real pi, f, phi_m, phi_0, alpha_m, phi, alpha, delta, phi_alpha, d_phi, d_alpha, d_delta, C_p , C_a, degToRad; pi = 3.14159265359; degToRad = pi/180; f = 0.1; // flapping frequency C_p = 0.8; C_a = 2.7; phi_m = 75*pi/180; // sweep angle amplitude phi_0 = 0*pi/180; // sweep angle offset alpha_m = 45 * pi/180; // inclination angle amplitude phi_alpha = 0 * pi/180 ; // inclination angle phase shift (20) // Angular displacement phi = (phi_0 + (phi_m / asin(C_p) * asin(C_p * cos(2 * pi * f * time))))*180/pi; alpha = ((pi / 2 - alpha_m) / tanh(C_a) * tanh(C_a * sin(2 * pi * f * time - phi_alpha)))* 180/pi; delta = 0.0; // Angular velocities d_phi = -(2 * pi * C_p * f * phi_m * sin(2 * pi * f * time)) / (asin(C_p) * sqrt(1 - C_p*C_p * cos(2 * pi * f * time)*cos(2 * pi * f * time))); d_alpha = (2 * pi * C_a * (pi/2-alpha_m) * f * cos(2 * pi * f * time-phi_alpha)) / (cosh(C_a * sin(2 * pi * f * time-phi_alpha))*cosh(C_a * sin(2 * pi * f * time-phi_alpha)) * tanh(C_a)) ; vel[0] = 0.0; vel[1] = 0.0; vel[2] = 0.0; omega[0] = d_alpha; omega[1] = d_phi; omega[2] = 0.0; } Also I wish to learn how the zone motion and things related to overset meshes. Kindly suggest me some resources to start (I have already read through fluent user guide but I did not understand much). Thanks in Advance. |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
Overset Mesh error : no startcell found ! | Cris ZC | STAR-CCM+ | 4 | September 9, 2019 11:43 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 02:10 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 03:19 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
