Meysam Paghandeh
Rep Power: 4 ![]() |
hi everyone
i write this udf code for simulation of wing in ansys fluent #include "udf.h" #define PI 3.1415 #define ro 1.225 real Vrel[20]; real alpha[20]; real Vx[20]; real Vy[20]; DEFINE_ADJUST(samplevelocity,d) { Thread *t ; cell_t c ; real x[ND_ND],z,y,db,d_new,xx,yy,zz; real z0[21] = {-2,-1.9,-1.8,-1.7,-1.6,-1.5,-1.4,-1.3,-1.2,-1.1,-1,-0.9,-0.8,-0.7,-0.6,-0.5,-0.4,-0.3,-0.2,-0.1,0}; //real z0[21] = {-1,-0.9,-0.8,-0.7,-0.6,-0.5,-0.4,-0.3,-0.2,-0.1,0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1}; real y0[21] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; real uu,vv,ww; int i; db = 0.1; for(i=0;i<=20;i++) { thread_loop_c(t,d) { begin_c_loop(c,t) { C_CENTROID(x,c,t); d_new = sqrt (pow(x[0] - 1.1,2) + pow(x[1]- y0[i],2)+ pow(x[2]- z0[i],2)); if (d_new<db) { db = d_new; uu = C_U(c,t); vv = C_V(c,t); ww = C_W(c,t); Vrel[i] = sqrt(pow(vv,2) + pow(uu,2)); alpha[i] = atan(vv/uu); Vx[i]= sqrt(pow(uu,2)); Vy[i]= sqrt(pow(vv,2)); } }end_c_loop(c,t) } } } DEFINE_SOURCE(xmom_source,c,t,dS,eqn) { #if !RP_HOST real x[ND_ND]; int i,j; real y0[21] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; real z0[21] = {-2,-1.9,-1.8,-1.7,-1.6,-1.5,-1.4,-1.3,-1.2,-1.1,-1,-0.9,-0.8,-0.7,-0.6,-0.5,-0.4,-0.3,-0.2,-0.1,0}; real x0[12] = {1.4,1.425,1.45,1.475,1.525,1.55,1.575,1.6,1.625,1 .65,1.675,1.7}; real L,D,U,chord=0.3,E,etta,y,z,r,rr,source,Fx,Fy,Fxtot al,Fytotal,etta1,r1,Dtotal,Ltotal,VO,total; C_CENTROID(x,c,t); double CL,CD; VO = C_VOLUME(c,t); real sourcex = 0.0; real sourceyy = 0.0; real sourcezz = 0.0; Fxtotal=0; Fytotal=0; Dtotal=0; Ltotal=0; total=0; for(i=0;i<=20;i++) { E = 0.25*chord; CL = -1*pow(10,-9)*pow(alpha[i],6) -2*pow(10,-7)*pow(alpha[i],5) +6*pow(10,-7)*pow(alpha[i],4) -6*pow(10,-5)*pow(alpha[i],3) -7*pow(10,-5)*pow(alpha[i],2) + 0.1155*alpha[i] + 0.0009; CD = 2*pow(10,-9)*pow(alpha[i],6) + 1*pow(10,-9)*pow(alpha[i],5) -6*pow(10,-7)*pow(alpha[i],4) -4*pow(10,-7)*pow(alpha[i],3) + 0.0001*pow(alpha[i],2) +3*pow(10,-5)*alpha[i] + 0.0059; for(j=0;j<=11;j++){ r = sqrt(ND_SUM(pow(x[0] - x0[j],2),pow(x[1],2),pow(x[2] - z0[i],2))); etta = exp(- pow(r/E,2)) * (pow(E,-2)* pow(PI,-1.5)); D = 0.5 * ro * Vrel[i] * Vrel[i] * 0.1 * chord * CD *etta/(12); L = 0.5 * ro * Vrel[i] * Vrel[i] * 0.1 * chord * CL *etta/(12); Dtotal+=D; Ltotal+=L; } sourcex += ((Dtotal*chord*0.1/0.6)*cos(alpha[i])-(Ltotal*chord*0.1/0.6)*sin(alpha[i])); sourceyy += ((Dtotal*chord*0.1/0.6)*sin(alpha[i])+(Ltotal*chord*0.1/0.6)*cos(alpha[i])); } C_UDMI(c,t,0) = -sourcex; C_UDMI(c,t,1) = -sourceyy; source = C_UDMI(c,t,0); dS[eqn] = 0; return source; #endif } DEFINE_SOURCE(ymom_source,c,t,dS,eqn) { #if !RP_HOST real source; real x[ND_ND]; C_CENTROID(x,c,t); source = C_UDMI(c,t,1); dS[eqn] = 0; return source; #endif } y0,z0 and x0 are coordinate of wing in define adjust sampling of velocity will be done and define_sorces for calculating body forces can anyone check my code, because i dont get correct resultts, thanks |
Alexander
Rep Power: 34 ![]() ![]() |
probably you want to calculate both source inside define_adjust macro (not inside one of the sources) and return source value through udmi (as it done with DEFINE_SOURCE(ymom_source,c,t,dS,eqn) )
best regards ****************************** press LIKE if this message was helpful |
actuator disk, actuator line, actuator-line, wind turbines |
UDF Error: Error code 126 | cilliant | FLUENT | 0 | June 30, 2023 06:52 |
Getting an error while compiling UDF code | Sohrabs | FLUENT | 2 | June 6, 2023 07:22 |
This UDF code was not working :( | Sumin Lee | FLUENT | 2 | June 30, 2022 07:18 |
UDF code help solve reaction rate equation palm oil | zirkov | Fluent UDF and Scheme Programming | 0 | February 13, 2017 10:34 |
write code UDF Fluent solve kinetic reaction rate equation palm oil | zirkov | FLUENT | 0 | February 13, 2017 10:16 |
