Accessing a inlet face stored UDM value at the outlet face.
Old   October 9, 2023, 12:31
Default Accessing a inlet face stored UDM value at the outlet face.
plotr is on a distinguished road
I am trying to write a UDF with two separate EXECUTE_AT_END functions. A value computed for the inlet EXECUTE_AT_END function must be accessed in the outlet EXECUTE_AT_END function.
I thought the best way to do this was using UDMs, however since the UDMs are stored per inlet face, I cannot access the data at the outlet faces.
Does anyone know of a way I can practically do this?
I also thought about defining and updating a global variable, but then the code returns zeros, which I presume is due to the parallelization.
Another option I'm looking at is transferring the data from the inlet face to the inlet cells and applying that value to all the cells in the entire flow domain. And then accessing the data again at the outlet faces from the outlet cells. But I am not sure how to do this properly.
Hopefully someone can help me out.
plotr is offline   Reply With Quote
Old   October 10, 2023, 05:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how to connect inlet and outlet
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 10, 2023, 06:26
But these posts state exactly the problem I currently have:
"You cannot transfer UDMs. Each boundary has its own thread and UDMs are identified using indices. The solution is to interpolate."
and then 1-1 mapping is only possible when there is an equal number of faces on both inlet and outlet. This is not the case for me.
I saw your reply to the other post with the following:
"if you want to apply some average value, you can create some global variable inside UDF to store and transfer pressure value between macros."
I tried doing this, by defining a global variable at the top of the code. However, the code kept returning zeros, so the variable was not updated at all. Could you perhaps give an example? That would be immensely helpful.
Old   October 10, 2023, 06:59
Alexander
show your code
best regards
Old   October 10, 2023, 07:29
I'll provide some parts that are mainly pertaining to the issue I believe, because the code is very long.
I define this global variable at the beginning:
static double im_pressure;
Then I define various UDMs for both the inlet and outlet:
DEFINE_INIT(init_UDMs, domain)
Thread* thread_inlet = Lookup_Thread(domain, inlet);
face_t f;
/*Initialize the user defined functions*/
begin_f_loop(f, thread_inlet)
/* loop over all faces of the inlet domain */
F_UDMI(f, thread_inlet, 0) = 0;
F_UDMI(f, thread_inlet, 10) = 0;
end_f_loop(f, thread_inlet)
Thread* thread_outlet = Lookup_Thread(domain, outlet);
begin_f_loop(f, thread_outlet)
F_UDMI(f, thread_outlet, 11) = 0;
F_UDMI(f, thread_outlet, 18) = 0;
within the first EXECUTE_AT_END, I have the following code:
begin_f_loop(f, thread)
function( one of the outputs is Pim)
F_UDMI(f, thread, 6) = Pim
im_pressure = Pim
end_f_loop(f, thread)
//Then the im_pressure (the value I want transferred) is called again within the second EXECUTE_AT_END function (also within a f-loop):
Pimt5 = im_pressure
If I print im_pressure in the first EXECUTE_AT_END function it does give me the correct value. But when I print it in the second function, zeros are returned. I feel like this might be caused due to parallelization.
Old   October 10, 2023, 07:30
Another option I had in mind was doing it in the following manner:
void store_data_from_inlet_face_to_outlet_face(Domain* domain)
cell_t c, c0;
face_t f;
Thread* t, * t0, * ct;
/* Loop over all faces on inlet and transfer the face data to cell data */
t = Lookup_Thread(domain, thread_inlet);
begin_f_loop(f, t)
c0 = F_C0(f, t);/* c0 and t0 identify the adjacent cell and thread */
t0 = THREAD_T0(t);
C_UDMI(c0, t0, 34) = F_UDMI(f0, t0, 34);
end_f_loop(f, t)
t = Lookup_Thread(domain, thread_inlet); // should this be the flow domain?
/* Loop through all cell threads in the domain */
thread_loop_c(t, domain)
begin_c_loop(c, t)
C_UDMI(c, t, 0) = ???; // Set UDM variable to the uniform value
end_c_loop(c, t)
/* Loop over all faces on outlet */
t = Lookup_Thread(domain, thread_outlet);
begin_f_loop(f, t)
t0 = THREAD_T0(t);
F_UDMI(f0, t0, 34) = C_UDMI(c0, t0, 34);
end_f_loop(f, t)
It is not finished yet for I do not know how to give every cell in the domain the same value.
Old   October 11, 2023, 01:20
Alexander
why is it static?
use real instead of double
best regards
Old   October 11, 2023, 05:09
I thought static would ensure the value is retained between the use of both EXECUTE_AT_END functions.
I tried your recommendation but, unfortunately, I still get zeros returned for im_pressure at the second EXECUTE_AT_END function. Whilst at the first EXECUTE_AT_END function im_pressure does have the correct value.
I still believe it is due to the parallelization.
face, inlet, outlet, thread, udm
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 459 September 12, 2024 12:47
using outlet velocity profile as inlet for next set of iterations tricha122 FLUENT 0 November 22, 2020 10:40
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
