October 3, 2023, 09:21 |
UDF for heat flux Bc
Mohammadreza Tohidi
Rep Power: 3 |
Dear friends
I wrote a UDF for one of my walls and this UDF will calculate the heat flux based on my simulation condition. The code compiled corectly in fluent by when I run the simulation i have the error of Error: floating point exception can someone review my code and help me through this? Thanks #include "udf.h" real T_inf_BC2 = 273.15; real h_BC2 = -2000.0; real h_BC3 = 10; // Typical value we used real m_snow_initial = 0.0005; // Constant initial value for mass of snow per unit area [Kg/m^2] real ice_density = 917; // Density of ice [kg/m³] - Typical value @ standard atmospheric pressure and 0 degrees Celsius real Boltzmann = 5.67 * 10e-8; //[W/m²·K⁴] real hif = 334000; // Heat of fusion of snow [J/kg] real dt = 300; // Time step length [s] real A = 0.009;//Aprx area of each cell [m^2] real K = 0.1; int cell = 1560; // Total number of cell on the surface DEFINE_PROFILE(heat_flux_bc, thread, position) { real x[ND_ND]; real flux; real time = CURRENT_TIME; real flow_time = RP_Get_Real("flow-time"); static real m_snow_time_step = 0; real snow_fall_rate; real ambient_temperature; real m_snow; real h_snow; real m_dot_melt; real T_snow; real h_BC1 = (K / h_snow * A); static int i = 1; int J = 0; face_t f; real T_wall; FILE* file; char line[256]; file = fopen("C:/Users/MOTOH/Desktop/file.txt", "r"); if (file == NULL) { Message("Error: Unable to open file.\n"); return; } while (fgets(line, sizeof(line), file) != NULL) { real file_time; real ambient_temperature_file; real snow_fall_rate_file; sscanf(line, "%lf, %lf, %lf", &file_time, &ambient_temperature_file, &snow_fall_rate_file); ambient_temperature = ambient_temperature_file; snow_fall_rate = snow_fall_rate_file; if (time >= file_time) { break; } } fclose(file); begin_f_loop(f, thread) { F_CENTROID(x, f, thread); T_wall = C_T(f, thread); if (T_wall < 273.15) { if (i == 1) { m_snow = m_snow_initial; h_snow = m_snow / (ice_density * A); T_snow = ambient_temperature; flux = (h_BC1 * (T_wall - T_snow)); m_snow_time_step = m_snow + (snow_fall_rate * dt); } else { m_snow = m_snow_time_step; h_snow = m_snow / (ice_density * A); T_snow = ambient_temperature; flux = (h_BC1 * (T_wall - T_snow)); m_snow_time_step = m_snow + (snow_fall_rate * dt); } } else { if (m_snow_time_step == 0) { flux = h_BC3 * (T_wall - ambient_temperature); } else { m_snow = m_snow_time_step; h_snow = m_snow / (ice_density * A); real q_cond_snow = (h_BC1 * (T_wall - T_snow)); flux = (h_BC2 * (T_wall - T_inf_BC2)); real q_melt = flux - q_cond_snow; m_dot_melt = q_melt / hif; m_snow_time_step = m_snow + ((snow_fall_rate - m_dot_melt) * dt); } } if (m_snow_time_step == 0.0) { J++; } F_PROFILE(f, thread, position) = -flux; } end_f_loop(f, thread) i++; Message("Percentage of area free of snow: %.2f%%\n", (J / cell) * 100.0); |
October 5, 2023, 04:31 |
Alexander
Rep Power: 34 |
at least one variable is not defined
for instance real h_BC1 = (K / h_snow * A); h_snow is not defined read compilation log
best regards ****************************** press LIKE if this message was helpful |
UDF for heat flux at membrane in membrane distillation process | yacarioca | FLUENT | 0 | March 10, 2021 00:58 |
UDF for reading radiative heat flux | ssa_cfd | Fluent UDF and Scheme Programming | 1 | December 14, 2020 01:53 |
uds flux - drift velocity - udf | johnwinter | Fluent UDF and Scheme Programming | 3 | November 25, 2017 05:07 |
UDF for UDS flux | gyf135 | Fluent UDF and Scheme Programming | 0 | October 13, 2015 21:02 |
UDF Mass flux computing | Carlo | FLUENT | 6 | November 23, 2014 22:59 |
