How to get the length of interface between two phases in VOF? |
September 29, 2023, 03:50 |
xingyu gao
I am currently using the VOF model for simulating gas-liquid two-phase flow, where the liquid phase is a solution containing two components (with one component being volatile). I have defined that the evaporation rate of the volatile component is proportional to the area of the phase interface. In this case, 2D quadrilateral meshes are used, so the area of the phase interface corresponds to the length of the phase interface within the cell. Besides, I used the geometric reconstruction scheme for interpolating cells that contain the phase interface. Hence, I would like to inquire if there is a way to obtain or indirectly calculate the approximate length of the phase interface under the geometric reconstruction scheme using a UDF? |
interface, vof model |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
UDF: how to identify interface in VOF model | process.abhi | Fluent UDF and Scheme Programming | 1 | April 19, 2012 03:11 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
