August 4, 2023, 03:10 |
Printing in a text using udf
Shaik Raheem
Rep Power: 3 |
Hello all,
I am using udf to print the variables in a text file. It is printing the results but for each timestep, it is printing two times. First, it is showing the correct values and next time it is printing -1#IND00 values. I don't know the reasong for printing like this. I am attaching the image of the printing file. Please reply if anyone knows about the issue. Thank you... |
August 7, 2023, 10:19 |
Vestdam
Rep Power: 9 |
I don't think I can help you with a solution, but can you show the UDF?
UDF and text commands | David | FLUENT | 3 | June 27, 2022 00:10 |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 09:33 |
UDF for energy source which includes a text file | mrwts | Fluent UDF and Scheme Programming | 0 | September 9, 2015 18:12 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 12:29 |
[OpenFOAM] Printing text in paraFoam | christian | ParaView | 2 | September 6, 2007 09:33 |
